View Poll Results: Air fuel ratio
Multiple Choice Poll. Voters: 4. You may not vote on this poll
2013-14 mustangs aid fuel ratio
I'm wondering what you guys are running at wot and I didn't know that the number the wideband says on the dash is lower than the tailpipe which is what most dynotechs use.
I believe your question needs some clarification. Are you looking for naturally aspirated AFR, forced induction or both? There is going to be a difference.
A good tuner will look a the data logs and not read AFR at the tail pipe. Ideally using a stand alone AFR meter with a serial connection on the leanest bank will suffice nicely or you can use the readings from the factory sensors.
You should get in touch with the Bama Team and send them a few datalogs for review. If your AFR's are truly at that point, than I think you could benefit from a tweak in fueling and pick up some more power.
If you've never datalogged before, here's instructions on how to do so. Make sure you zip the datalogs into a file when sending it to the Bama Team too.
Hit me up if you have any other questions or concerns!
Shane
