View Poll Results: Air fuel ratio
11-11.5
0%
11.5-12
25.00%
12-12.5
50.00%
No idea lol
25.00%
Multiple Choice Poll. Voters: 4. You may not vote on this poll
2013-14 mustangs aid fuel ratio
Old Apr 6, 2014 | 10:47 AM
Gogoggansgo's Avatar
I'm wondering what you guys are running at wot and I didn't know that the number the wideband says on the dash is lower than the tailpipe which is what most dynotechs use.
Old Apr 6, 2014 | 11:48 AM
2014GHIGGT's Avatar
I believe your question needs some clarification. Are you looking for naturally aspirated AFR, forced induction or both? There is going to be a difference.
A good tuner will look a the data logs and not read AFR at the tail pipe. Ideally using a stand alone AFR meter with a serial connection on the leanest bank will suffice nicely or you can use the readings from the factory sensors.
Old Apr 6, 2014 | 09:30 PM
Five Oh Brian's Avatar
Supercharged cars need to run a little richer than NA. I ran my Vortech'd '07 GT around 11.6:1.
Old Apr 6, 2014 | 09:47 PM
Both my bama tunes run at 11.7 and I thought that was lean but brenspeed said that was spot in go figure
Old Apr 6, 2014 | 10:16 PM
I thought lower number meant it was leaner not realizing it's the other way around
Old Apr 6, 2014 | 10:18 PM
both but u was reading my afr wrong anyways
Old Apr 7, 2014 | 11:39 AM
AMWill's Avatar
Former Vendor
11.7 for a naturally aspirated engine is a bit on the rich side actually. For the 11-14 Mustangs, we usually like to see in the 12.0-12.4 range. 11.7 is the sweet spot for light boost or nitrous applications!
You should get in touch with the Bama Team and send them a few datalogs for review. If your AFR's are truly at that point, than I think you could benefit from a tweak in fueling and pick up some more power.
If you've never datalogged before, here's instructions on how to do so. Make sure you zip the datalogs into a file when sending it to the Bama Team too.
Hit me up if you have any other questions or concerns!
Shane
Old Apr 8, 2014 | 01:19 AM
That's where im at but these are older tunes but I'm getting my boss manifold and jlt cai installed so I will be in touch thanks
Ecostang
Nov 3, 2022 08:50 PM
JonathonK
GT350
38
Apr 28, 2016 08:11 PM
retiredf5
Ecoboost
Jul 21, 2015 05:54 PM
DerekShiekhi
Jul 14, 2015 10:32 PM
