2011 V-6 EPA certified 31MPG!
Old Mar 4, 2010 | 09:48 AM
2010MustangGT's Avatar
Then you, my friend, are not enjoying your GT, are you?
haha, It's a rare occurrence... combined I'm sitting at 15.8. mainly cuz I like to use the 1-3 gears every now and then.
Old Mar 4, 2010 | 10:13 AM
topbliss's Avatar
my combination mileage is a little over 20 mpg.. and its mostly city driving
Old Mar 4, 2010 | 10:29 AM
Ltngdrvr's Avatar
Originally Posted by topbliss
don't worry, I know what Im doing.. 30 mpg is easy achievable on the highway..
You may get a mpg or 2 better with the 6 if you take it easy but 36 is out of the question..
I'd say 30 MPG out of a '07 GT is out of the question too, but if you are able to get 30 MPG out of a '07 GT that is EPA rated at 23 MPG then I don't know why a '11 V6 that is EPA rated at 30-31 MPG shouldn't be able to get 35-36 MPG going by how yours is doing.
Doesn't really matter, I'd be happy just to have a new 2011, whatever the fuel mileage ends up being. I probably couldn't keep my foot out of it enough to even get the rated MPG.
Old Mar 4, 2010 | 10:38 AM
topbliss's Avatar
the epa rating was 25 for my car. Not that it matters. I'm just as shocked as you are.. Like I said I hardly ever get under 20 mpg with it even in combined city driving..
Old Mar 4, 2010 | 11:46 AM
PTRocks's Avatar
2007 was the last year before the EPA introduced new testing methods to more accurately reflect real world driving. As per the EPA site:
Beginning with 2008 models, all fuel economy estimates based on new test methods, which EPA finalized in December 2006. The new methods better account for actual driving conditions that can lower fuel economy, such as high speed, aggressive driving, use of air conditioning, and cold temperature operation. The new estimates will give drivers a more accurate estimate of the fuel economy they are likely to achieve on the road. Because of the new methods, the estimates for most 2008 models will be lower than their 2007 counterparts. To aid consumers shopping for new cars, EPA has also redesigned the fuel economy window sticker posted on all new cars and light trucks to be easier to read and understand.
So does this mean that with the new ratings, it will in fact be possible to achieve a larger increase over the rated highway mileage??
Old Mar 4, 2010 | 11:55 AM
PTRocks's Avatar
An interesting detailed read of the new methods, with a comparison to older methods used since the 70's. One point of interest is that the actual new tests are only required starting in the 2011 model year, so the Mustang is one of the very first cars to be officially tested using the new methodology. From 2008 until 2010, the downward revised EPA mileage ratings have only been estimates.
Old Mar 4, 2010 | 11:58 AM
97svtgoin05gt's Avatar
Enjoying it.. but driving slow..
Is this possible??
Old Mar 4, 2010 | 12:09 PM
orange3.9stang's Avatar
Originally Posted by whysoserious
I sort of thought the same thing, of course Ford in all of their ads has been quantifying this by emphasizing that the mileage has remained the same while power and torque numbers have increased dramatically. True. I do think, however, that better fuel economy could have been achieved if they went with a double overdrive transmission instead of the single in the MT82. But then of course we wouldn't have missed out on some good acceleration with the close ratios and taller 1-4 gears. We shall see. This is going to be an interesting spring.
The V6 with base 17" tires & std. axle @ 75 MPH will be doing 1798 or 1751 RPM in 6th (MT or AT).
or
With the optional 3.31 gears & 18" tires you'd be at 2211 or 2182 RPM in 6th.
With the 2.73 rear, you really don't want cruising RPM to be much lower than this with the torque limitation of a V6.
1st gear in my '04 was way too much torque for the factory open differential (one wheel peel was too easy and embarrasing) but just perfect w/ T-Lok and the '11 will be within 1% of this ...
2004: 3.27 rear, 3.350 1st gear & 25.744" dia tires = 4426 RPM @ 30 MPH
vs.
2011: 2.73 rear, 4.236 1st gear & 27.252" dia tires = 4413 RPM @ 30 MPH
However cruising at 75 MPH in my '04 the engine is turning 2246 RPM ... so in my mind the '11 with std. axle ratio will basically be a DOUBLE OVERDRIVE.
With the optional 3.31 axle a "double overdrive" would be beneficial, but Ford is not going to offer up 2 different trannies !!
Doug
Old Mar 4, 2010 | 12:15 PM
I was really hoping that the official EPA ratings would surpass the preliminary estimates as this also happened with the new Camaro last year.
The orig. estimates for the Camaro (both V6 & V8) were not impressive at all, and the final EPA numbers were at least 2 MPG better from what I remember.
Doug
codeman94's Avatar
I'd like to see one in white.
Old Mar 4, 2010 | 12:36 PM
krnpimpsta's Avatar
Yeah.. I'm around 13.5 with 50% highway, 50% suburban. I never knew we had gears past 1-3..
Best I've gotten, when taking it really easy, cruise control at 70mph on the highway, was about 20mpg combined.
(FYI to all you city-mpg quoters.. can't really call it "city" driving unless you're in a grid of tightly packed roads where there's a red light every 500 feet.. I get about 8-10 mpg in the city)
Old Mar 4, 2010 | 01:38 PM
"making it the first production car ever to achieve a combination of over 300 horsepower and 30 mpg."
That in and of itself is a pretty amazing feat.
Nicely done Ford. Really upped the bar.
Old Mar 4, 2010 | 01:57 PM
SteedaGus's Avatar
Originally Posted by RandyW
Half of the Motor Trend commenters are impressed and half don't believe that the EPA ratings are valid. I think a lot of people are mentally stuck in the 70's and 80's. A generation ago everybody complained that their cars made less mileage than the EPA rating. With today's cars, though, the EPA ratings are often surpassed in real world driving. Do you suppose there are a lot of people that just don't know that it's OK to put their car in it's top gear when they are on the highway? I'm afraid I have family members that often drive one gear down from top gear even though they're going 60+ on a flat highway.
I agree, and personally in my experience with my 2006 GT and my Mercury Milan, I can easily exceed the EPA ratings for both vehicles when driven right. In fact the newer the Ford, the easier it seems to be to beat the mileage ratings. My 2008 Milan is rated at 26 highway, I can easily get around 28 without trying to hard. Even more if I really try, but that gets boring. LOL My 2006 GT was rated at 24, and I can get 25 to 26 even with the steeper gearing when I need to.
For the person here who reported 30 miles per gallon out of his 2010 GT, I've had other customers tell me they've gotten close to that, of course you are not enjoying the car driving it like that, but gas mileage and full throttle don't mix anyway.
If Ford claims 30 to 31 miles per gallon from the 2011 V6, I am betting people will easily achieve that.
Old Mar 4, 2010 | 03:10 PM
Five Oh Brian's Avatar
Then you are not truly enjoying it for its intended purpose, IMO. Step on it and burn some rubber (and dead dinosaurs)!
Old Mar 4, 2010 | 03:17 PM
My wife has a 2008 Mercury Milan Premier with the 2.3L and automatic. It's EPA rated at 28 mpg highway. I recently drove it from Seattle to Tacoma, WA on I-5 at 60 mph on cruise control and nailed 46+ mpg (fairly flat stretch of highway). On longer trips with more elevation changes we get 33+ mpg driving 60-65 mph. When I'm really trying to hustle somewhere (70-80 mph), it still manages to get 29-30 mpg. The 2008 EPA measurement changes have really made the mpg numbers more realistic - even a bit conservative and easy to surpass.
Old Mar 4, 2010 | 03:26 PM
2011 Fastback's Avatar
Mustang
Kudos to all that are getting the V6, I ordered a GT so hopefully EPA specs will be out soon....but I know they wont be as good as that...oh well....
Old Mar 4, 2010 | 03:27 PM
Ltngdrvr's Avatar
All these MPG numbers you are giving, 46+, 33+, etc. Are these numbers taken from a mileage readout from the computer? If so, those numbers are only instant readings, not an average number. And an average number is what you have to look at. When I used to drive eighteen wheelers for a living, the last truck I owned had a mileage readout and I could make it go to 99 MPG when going downhill but it sure wasn't going to actually get anywhere near to that as an average.
The EPA fuel economy numbers are average numbers, not written in stone, and they have a disclaimer that tells you that your mileage may vary.
Old Mar 4, 2010 | 03:39 PM
Bert's Avatar
Originally Posted by orange3.9stang
I was really hoping that the official EPA ratings would surpass the preliminary estimates . . .
they did -- preliminary estimate was 29 highway for the manual, 30 for the automatic . . . so they each went up by 1 . . . I think the Camaro went from 27 to 29, not that much bigger of a change
I rented a V6 Camaro for a one-day test drive and got 25.9 MPG overall measured average, 30.5 according to the computer on a simulated commute . . . the mileage computer on the Camaro is average only, so I reset it before the simulated commute and read it when done, this was not an instantaneous reading and I believe the computer is very accurate . . . so yes it is possible to do better then the new EPA rating . . . in the past the rating was about the best you were ever going to do
(in case you are wondering, I liked the Camaro a lot . . . but waiting for the new V6 Mustang before I decide which to buy)
Old Mar 4, 2010 | 03:52 PM
UnrealFord's Avatar
My 2004 Mach1 with auto was rated at 22mpg, we drove down to MustangWeek in SC. And me and my brother achieved over 24, thats with a few spirited blast on some occasional spots..
Old Mar 4, 2010 | 04:16 PM
  #40
Bert ... I know they did and I'm very happy about it !!
I'm hoping to pull off my 400 mi / week commute on one tank of gas. My '04 gets 25-27 MPG with my 80-90% of interstate driving and low-fuel light comes on between 320-360 miles. Usually drive 20-30 miles past the light and this can leave me with less than a gallon left upon fill-up, so it just does not cut it.
Doug
