2011 Top speed guesses
Old Jan 2, 2010 | 12:40 PM
eci's Avatar
eci
Would be psychotic to attempt speeds even close to those numbers in a factory Mustang regardless of HP. The suspension isn't up to the task either.
Old Jan 2, 2010 | 01:05 PM
Adam's Avatar
I live in Orange County. As long as it can reach 90mph I'm happy.
Old Jan 2, 2010 | 01:07 PM
mustangmaniak2010's Avatar
Note this is the v6
Old Jan 2, 2010 | 01:15 PM
eci's Avatar
eci
Originally Posted by mustangmaniak2010
Note this is the v6
What the speedo goes up to means nothing.
Note this is a GT500, I guess it can only do 160?
Our G8 GT speedo goes to 180 and there is NO WAY that car can hit that speed.
Old Jan 2, 2010 | 01:28 PM
jsaylor's Avatar
I think the GT is going to eclipse 165mph pretty easily sans a limiter that stops the fun short, and frankly, that is way more than enough. That said, the suspensions capabilities wouldn't worry me at those speeds nearly as much as aerodynamic instability would.
Old Jan 2, 2010 | 01:32 PM
eci's Avatar
eci
165 is crazy fast in any car on the street and retarded. Those speeds are for the track only.
Old Jan 2, 2010 | 01:57 PM
Boomer's Avatar
You won't catch ME trying to reach the limit....
Funny how some people look at the speedo and quote it as what the car can do.
I always got a laugh outta that
Old Jan 2, 2010 | 01:58 PM
Boomer's Avatar
Note this is the v6
Also note the GT has a 7k redline....
So they can use the same parts
Old Jan 2, 2010 | 04:23 PM
SpOnkey21's Avatar
I am guessing the aerodynamics will be better than a fox convertible, and even the v6 has way more power than that. The V6 will easily be capable of 155 and 165 is a conservative guess; and I am supremely confident the GT could do at least 170 without the governor. My fox convertible had stock rims and standard off the rack tires with stock suspension and it could have gone to 155. You can debate safety, but I am sure the new GT can do it, 175 isn't a stretch either. I suppose 185 is a high guess, but not by much in my opinion.
Old Jan 3, 2010 | 05:47 PM
Dave07997S's Avatar
I can think of only a handful of car companies that don't restrict their topspeed of thier vehicles. I know Porsche doesn't as well as Ferrari as they are all rpm/drag limited. My 997S will hit 7200rpm in 6th gear (redline) and it would equate to 185mph. The 2011 GT was able to hit redline in 5th ger (1:1) this would equate to 171mph...I think this is very attainable.
Dave
Old Jan 3, 2010 | 06:05 PM
GT40 2's Avatar
Id say 175 for the GT, and 160 for the V6.
Old Jan 3, 2010 | 08:12 PM
06GT's Avatar
Who cares, you'll hardly ever get the chance to hit that type of speed outside of a track or without going to jail.
That being said, if it's "limited" to 155mph, that will be enough to protect the Mustang's rep in the E-Peen contests.
I'd rather have some more rear gear like a 3.73 for added acceleration, losing some top speed is not an issue.
Old Jan 3, 2010 | 08:25 PM
rodriguez256's Avatar
My 01 Monte carlo SS had a speedometer of 140 but I got it up to an est. 150.
Old Jan 8, 2010 | 09:41 AM
PTRocks's Avatar
These are 'optional' tire specs I have found for some of the cars.
V6 235/50/R18 97W
GT/CS 245/45/R19 98W
GT w Brembo package 255/40/R19 Summer Tire, later 245/40/R19 Z Rated Tire
GT 245/45/R19 98W
Old Jan 8, 2010 | 09:52 AM
Dixie_Flatline's Avatar
Remind me to stay off whatever roads you guys are travelling.
Old Jan 8, 2010 | 10:59 AM
Cusp's Avatar
Originally Posted by eci
They will be drag as well as power limited before they hit the "redline in 6th" speed. The 505HP 3100 lb Z06 can't even hit redline in top gear stock. 412HP and the Mustangs aero isn't enough to reach 185.
It makes its top speed of 207 in 5th not 6th.
Its quite a study to estimate that the speed actually will be. You have the drag coefficent and that inverse square law. You need a lot more power to go a little faster at high speeds. If you could go 140 with 300 HP, you could go 165 with 400.
Old Jan 9, 2010 | 03:47 PM
AWESOMO 4000's Avatar
If the 4100lbs SRT8 Challenger can hit 173mph, I'm pretty sure the GT will be able to match that, considering it's toting around 500lbs less flab with equally heinous aerodynamics and frontal area.
Old Jan 9, 2010 | 09:58 PM
RandyW's Avatar
Just how heinous are the aerodynamics? I don't recall every reading what the coefficient of drag is for either car.
Old Jan 11, 2010 | 02:55 PM
bob's Avatar
bob
Weight has nothing to do with top speed unless you have to get there in a certain amount of time, anyways I'm just throwing out that the 07-09 GT500's with 500hp on tap could barely crest the 160 mph mark (163 or so ungoverned IIRC).
While I'm positive neither V6 or V8 will go faster than 155 in stock trim, I'm betting a GT flat out wont go much past that anyway even with the areodynamic improvements put into place with the '10 models.
Old Jan 11, 2010 | 04:08 PM
  #40
I like how Ford swapped the tach over to the right on the 2010+ cars, like the 07-09 GT500 SVT cluster. Driving an 09 and 10 back to back, I prefer it on the right. More visible in the corner of your eye.
