2011+ Mustangs with CDC Light Bar?
Old May 3, 2014 | 07:51 PM
TheDivaDanielle's Avatar
Just wondering if I could get some input here from others that have installed the CDC light bar.
I had it installed the other day with no light hookup, and the wifey and I set out to get the light function hooked up as well as get the EQ for the stereo dialed in.
We tapped the Yellow wire with silver stripe and the harness white wire with blue stripe like the directions say and the lights don't work at all, can't figure it out, there has to/must have been a wiring change.
Looking for input from others here. I didn't buy it for the light function anyway, so I could care less if it lights up, but I'd like to get it to light up.
Old May 4, 2014 | 07:40 PM
JimC's Avatar
legacy Tms Member
First question. Is the top down? The brake light only works with the top down.
Or do you have the newer stye that also has the courtesy lights that light up the back seat when you open the door?
Old May 4, 2014 | 07:50 PM
top was down of course, tried top up too. and I ordered it w/out the courtesy light. felt redundant.
Old May 5, 2014 | 07:18 AM
rmurer's Avatar
so you didn't order it with the brake light installed? or is courtesy light something else?
Old May 5, 2014 | 07:48 AM
it has the brake light, but not the interior light.
Old May 5, 2014 | 08:11 AM
rmurer's Avatar
Oh okay.
all i can recommend is see if your spliced into the right wires. Maybe see where those wires go to the 3rd break light or see what colors go to them. best way to see if your using the right ones.
Old May 5, 2014 | 08:19 AM
Originally Posted by rmurer
Oh okay.
yeah, going to pour over it again today. was trying to get wifey involved, and I let her handle the wiring part. not that I don't trust her, she's no dummy, but something isn't right.
Old May 5, 2014 | 08:32 AM
rmurer's Avatar
Eh wiring can be tricky, even if it looks right and you followed the directions it can still cause issues some how.
If there are still issues i would invest in a voltmeter and test to see if you're actually getting voltage when you apply the brake. There could be a possibility that the light bar is not working properly.
Old May 5, 2014 | 09:17 AM
yeah we have one somewhere, wifey said she'd dig it out, but we never got back to it yesterday.
Old May 5, 2014 | 09:47 AM
Another thing I've noticed on Ford cars - a lot of times they use the same color wires for different things. It makes tracking down the correct wire you're trying to tap into...a big fat B.
ustabawannab
May 3, 2016 07:54 AM
Mackitude
Aug 13, 2015 01:05 PM
Michael Follett
Jul 24, 2015 06:58 AM
JonathonK
Jul 22, 2015 04:10 PM
