2011 3.7 mustang cranks like it wants to start but doesnt
Old 3/19/23 | 03:57 PM
Bash617's Avatar
i got a 2011 mustang it came in ticking and knocking at the top of engine. i broke it down to the camshafts and lifter caps but there was no damage, the timing chain was loose and the car was losing oil pressure when i was idle. i bought a new oil pump, timing chain kit with crankshaft sprocket, all 4 camshaft sensors, and crankshaft sensor, vvt solenoids, crankshaft pulley, iridium spark plugs, and coils, oil pressure switch, air filter and throttle body, i have the official blueprints to the car down to the bolts and part numbers for everything. i know nothing was put on wrong, im getting fuel spark and compression, i can blow a shop rag out of the cylinder soo no problem there. i gets up to like 500rpm but doesnt want to turn on.and before i closed everything i turned the engine just so i know everything was smooth in the engine. and all of the timing marks matched up like the blueprints said they would.
Old 3/19/23 | 04:54 PM
m05fastbackGT's Avatar
Did you check the cam phasers? If not, they are well known for causing engine ticking, depending on mileage... Meanwhile, welcome aboard!
MRkoehl1
6/21/21 11:03 AM
chrison600
9/4/16 07:34 AM
bigaaron
1994-2004 V-8
8/22/15 01:06 PM
tierzu
1994-2004 V-6
3/31/13 09:44 PM
John Hatton
1994-2004 V-8
8/23/12 07:14 PM
