The 1/4 Mile Thread
Old Apr 27, 2010 | 04:45 PM
InsidiousGT's Avatar
The 1/4 Mile Thread
There have been many discussions on the track times in different review threads, so I set out to put it all together and average it out for discussion purposes. Well what I found was after reading every review, the only two that actually put the car to the pavement were MT and C/D, all others were estimated. So here are these results. I'll update the thread as more come in.
Code:
-- MotorTrend --
-- 3.73s, Brembos --
435hp / 404 lb-ft (at crank, estimated)
378hp / 351 lb-ft (at wheels)
0-60 @ 4.3
12.8 @ 110 mph
-- Car And Driver --
0-60 @ 4.6
13.2 @ 109 mph
-- InsideLine --
395hp / 365 lb-ft (at wheels)
Further, lets compare to historical data. For anyone who hasn't seen it, this site is absolutely great.
http://www.stealth316.com/2-calc-hp-et-mph.htm
Its a good read for any gearhead. They basically took all kinds historical data on drag strip cars, put them on a graph, and saw what sort of correlation they followed. We all know lower pounds per horsepower = better ET, but this guy took it to the next level.
Anyway, if you use his "LRT Formulas", you'll see the expected ET for a 3600lb car with 412 hp is 12.8 @ 111. Right on the MT review.
Also, if you work backwards, put in the weight and mph/ET from the Car and Driver review, it shows the HP should be around 375. Sounds to me like they were sandbagging it.
Old Apr 27, 2010 | 06:39 PM
Boomer's Avatar
MT got 12.7 in their 2nd test IIRC...
Old Apr 29, 2010 | 04:19 PM
For some reason I can't edit the original post... but here are some more numbers coming in...
Code:
-- Evolution Performance --
13.2 @ 110   (poor track conditions)
https://themustangsource.com/showpost.php?p=5856046&postcount=37
368 hp / 352 lb-ft  (at the wheels)
https://themustangsource.com/showpost.php?p=5857005&postcount=188
Old Apr 29, 2010 | 04:30 PM
DeathChill's Avatar
The 12.7 run by the guy on the other forum appears to be done using a G-Tech like device, not a real track. Might want to edit it out until there is confirmation one way or the other.
Beouch
Sep 16, 2015 06:14 PM
SterlingStunner
Sep 16, 2015 12:30 PM
JTB
Motorsports
Sep 7, 2015 10:20 PM
