Gt500 pedals
If you buy the One's from Kevin you need to replace the gas pedal. The brake and clutch (if you have one) only the rubber part needs to be removed and then slide the new one's on. If you buy the one's from CDC then the gas pedal goes on with 3m tape and the brake and clutch go on the same way as the one's Kevin offers. BTW the CDC one's are cheaper since your not replacing the entire gas pedal. It's up to you though which one's you want. I have the one's from CDC check out my sig for pics.
9/8/15 10:45 AM
