Picked up a 2005 FX4 4x4
Old Jul 31, 2014 | 06:55 PM
needs an engine rebuild or replacement 5.4L. Kbb shows it worth around 9700 in good condition.
http://www.ebay.com/itm/2005-Ford-F150-FX-4-4X4-needs-rebuild-on-engine-/251597938231?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2047675.l2557&nma=true&si=Y5AtaTPwyIcasEPvj%252Fowh1tL4As%253D&orig_cvip=true&rt=ncJust need to get it hauled home. I got a quote of 414.00 bucks for that
Old Jul 31, 2014 | 07:09 PM
stupidgenius36's Avatar
Just Plain Rude!
Congrats on the new ride. Hopefully the rebuild doesn't end up costing too much though...
Old Aug 1, 2014 | 06:36 AM
Yea rebuild without a bore should be around a grand give or take. I found a 5.4 with 59k on it for around 2200 and a long block for around 3k.
Old Aug 15, 2014 | 06:40 AM
engines out
Old Aug 15, 2014 | 06:46 AM
Just Plain Rude!
I like to think my engine doesn't look that bad inside, but deep down...I know it probably does.
Old Aug 15, 2014 | 07:27 AM
Where's the gear thingy that the timing chain wraps around on the end of the cam shaft
Old Aug 15, 2014 | 09:42 AM
Yea it looks like the oil wasn't changed in like 100k miles. The worst I have seen in the 12+ or so engines I have rebuilt.
I was in the process of taking the head off when I took the head picture. Gear was on the work bench.
I need to get the heads off to see if I will rebuild it or just get a reman engine. That oil pan has 1/4 inch of slimy metal speckled sludge in it. Nasty
Old Aug 15, 2014 | 10:13 AM
tom281's Avatar
Dang that does look bad
Old Aug 15, 2014 | 12:22 PM
Oil changes are highly overrated.
Old Aug 15, 2014 | 07:06 PM
The guts of this engine look better than the jeep did recently. I axcutally expected to see much worse damage. The crank bearings are scored up a bit. The connecting rod bearings look very good. The cylinders look pretty freaking good too. The pistons have most of the coating wore off them and some light scoring.
Old Aug 15, 2014 | 07:08 PM
Oh yea on a couple of those middle piston the second ring was frozen.
Old Aug 16, 2014 | 07:00 PM
now to decide on rebuilding vs a remaned engine or low miles replacement
Of course I need to check to see if its needs to be bored, if it needs a bore I will probably just go the reman/replacement engine. Block werk costs to much.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=390907687477
looking this this one or
http://www.ebay.com/itm/111414162588?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AITof course they want you to replace a bunch of stuff that doesn't need to be replaced so they will cover the engine under warranty.
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
Autotooner
Nov 24, 2017 12:42 PM
yabutt
Oct 23, 2015 01:05 PM
