Gary's ***Project Bronco***
Old Nov 29, 2012 | 08:45 PM
  #461
Shelby08's Avatar
Originally Posted by 2k7gtcs
I'm still traditional and I'd hope the young man would be too. I wouldn't put much credence into a boy that didn't drive his date to the prom.
And he is 2.
Sadly (at least up here) most guys her age don't have those traditional values/habits that I was brought up with.
well I imagine you'll have a couple more cars by then!
Old Nov 29, 2012 | 08:47 PM
  #462
Only one more. The Shelby. After that I'm done.
Unless they strike oil on my land in which case I'll add a Ford GT. But that won't happen anyway.
Old Nov 29, 2012 | 08:48 PM
  #463
Shelby08's Avatar
Well that's a good way to close it out I suppose...
Old Nov 29, 2012 | 09:01 PM
  #464
06blackvertstang's Avatar
So back to laying claim to Gary's cars... No one ever actually claimed seven. Sooo mine!
Old Nov 29, 2012 | 09:03 PM
  #465
Shelby08's Avatar
If you check the records I claimed all vehicles other than the raptor that was already taken....but I'll share!
Old Nov 29, 2012 | 09:07 PM
  #466
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
You guys might wanna spend some time researching. I'm pretty sure all of his rides are claimed, mostly way before you showed up
Old Nov 29, 2012 | 09:10 PM
  #467
Shelby08's Avatar
Can you let me be happy for a little while!?!?!
  #468
future9er24's Avatar
I just plain refuse to believe this
  #469
Blue Notch's Avatar
His rides have been claimed so many times, it's not even funny anymore.
Old Nov 29, 2012 | 09:22 PM
  #470
You're gonna love the goodies I got for the Notch this week from MM.
Torque bar, panhard rod, k-member, camber/caster plates, MM A arms for coil overs.
Old Nov 29, 2012 | 09:25 PM
  #471
Consider me as green as my bullitt is
edit: also what coilovers are you running/planning on if not the MM ones?
Old Nov 29, 2012 | 09:27 PM
  #472
Well I only want to take it apart once. Figured I'd do all suspension and brakes while I'm in there and then move on to power train them interior and finish up with fixing the **** dent.
Old Nov 29, 2012 | 09:33 PM
  #473
MM has been running these deal of the day things. So I've been buying the deal each day. Maybe tomorrow it will be coilovers.
Anyway I plan to use their coilover conversion for the fronts with my illumina Tokicos. On the back ill run their regular springs made to work with the torque arm and use their adjustable LCAs.
The cool thing about the torque arm and panhard setup is that it eliminates the UCAs which as you taught me is the real problem with these cars and the snap steer.
Old Nov 30, 2012 | 05:18 PM
  #474
That notch is going to HAUL
take lots of pics of the install if you can. I eventually would like to have a lot of those bits on my car someday. this way i can cheat and see what was hard before I get to it
Old Nov 30, 2012 | 06:41 PM
  #475
Well the fist step will be the subframe connectors. Had them for years and never put them on. Can't install the torque arm without it because it gets welded to them
Old Nov 30, 2012 | 06:44 PM
  #476
lime05's Avatar
Is it time for a notch thread!?
Old Nov 30, 2012 | 09:43 PM
  #477
https://themustangsource.com/f634/he...roblem-501444/
Old Dec 26, 2012 | 11:37 AM
  #478
Well we have a problem with the Bronco. Whenever the temperature drops the seals on these **** El Dorado rear brake caliper leaks. Just the drive side. I heard this could be an issue in colder climates. ****ing GM!
Old Dec 26, 2012 | 11:54 AM
  #479
shurtual86's Avatar
Putting GM parts on a Ford
Old Dec 26, 2012 | 06:12 PM
  #480
07S197's Avatar
Swamp Donkey Man Cans
Gary<-----
