Terrible, Terrible Mileage
Old Jan 19, 2013 | 12:43 PM
cntchds's Avatar
In the past couple of tanks I have been getting about 15-16 mpg down from 19-20... Last tank I got 180 miles...
At idle it almost sounds like there is a backfire every once in a while. I pulled a couple plugs and noticed there was a white residue on them after only about a year of having them in since my head gasket was changed. I read that it could be a clogged air filter, and the guy at the parts store said that I should check vacuum lines.
Where are all the vacuum lines? Is there a way to test the plastic ones, or do I just have to listen to them and see if I can hear anything? Do you guys have any other things I should look for?
Thanks in advance.
Old Jan 19, 2013 | 01:16 PM
Getportfolio's Avatar
Clean air filter, change oil, check tires.
Old Jan 19, 2013 | 01:30 PM
cntchds's Avatar
1. Will do.
2. Did 2 days ago.
3. All four are at 33psi.
Old Jan 19, 2013 | 02:35 PM
Rather B.Blown's Avatar
Like Father...
I ♥ Sausage
Thanks in advance.
You can take a can of starting fluid and spray a little at a time around the vacuum lines to see if you have a leak. If the engine speeds up when you spray it around a certain one, its leaking and pulling in the starting fluid.
Old Jan 19, 2013 | 02:48 PM
cntchds's Avatar
This might be a very dumb question, but wouldn't a vacuum leak like that make it run more lean since it would be pulling in more air than expected?
Old Jan 19, 2013 | 03:20 PM
Good trick.
Old Jan 19, 2013 | 06:35 PM
Jack up the rear end then put your car in n and see how easy the rear wheels turn. Engine off of course. I had a rear caliper hanging up and after I fixed that my MPG's increased. just a thought
Rando
Aug 25, 2021 11:12 AM
K.A.I.N
13
Dec 26, 2015 01:29 PM
Fred_Garvin
Sep 17, 2015 04:10 PM
MustangGTCS13
Sep 17, 2015 07:38 AM
oldnjguy
Sep 10, 2015 02:39 PM
