Symptoms of a bad O2 sensor? or...
Old Jun 19, 2014 | 12:26 PM
The Mad Dooby's Avatar
Curious to see if anyone can help me. When accelerating, my car will pull hard until 3-3500 rpm, then it will start sputtering and coughing and won't rev up much more. It does this off and on. Some times it will pull hard the entire way, and others it just craps out. My guess is its either an air or a fuel problem, but I'm trying to pin point what specifically. If you can help me out that'd be great!
Old Jun 19, 2014 | 03:53 PM
zeroaviation's Avatar
Is it throwing any codes? Do you have a tuner to pull codes? Sometimes, a code will throw and not illuminate the CEL\
-Mat
Old Jun 19, 2014 | 06:58 PM
Nothing on the dash, but the check engine light does come on every now and then. I'll hook the computer up and see
Old Jun 23, 2014 | 06:25 AM
change the fuel filter if it hasn't been done in a while
Old Jun 23, 2014 | 12:23 PM
I was troubleshooting on the internet and it also sounds like it could be an issue with the smog and emission equipment. Since I have cat deletes, the emissions equipment could be working against me.
Old Jun 26, 2014 | 05:16 PM
fstbck70's Avatar
Coil packs. Might want to give them a look-see
Old Jun 28, 2014 | 03:13 PM
It's a 95. There isn't any coil packs.
Old Jul 8, 2014 | 08:28 AM
tacbear's Avatar
If you have over 100,000 miles this will be clogged up "light off" converters. Mustang V6's are notorious for this. One way to test is to take the forward O2 sensors out and if it drives better you need new converters...or do like I did on my daughter in laws Mustang and "gut" them!
Old Jul 8, 2014 | 09:20 AM
LivinTheStangLife's Avatar
He said he has no cats
Check mass air flow sensor. We had a 95 v6 that would sometimes run ok and then it would just quit accelerating and it would leave me on the highway going 50 because it wouldn't do anything. It wouldn't accelerate from stops hardly when it was happening and it wouldn't go over like 3k-3500k rpms. Ended up being mass air flow sensor bad
Rando
Aug 25, 2021 11:12 AM
trackpack13gt
Jul 25, 2017 05:29 PM
