Stang with problems
Stang with problems
High guys, I'm new to the stang world. I just purchased a 1995 GT and already having issues! The car has a shudder in neutral and through all gears. It bogs down when cold and idles like has a cam in it. Its driving me nuts! I have replaced the MAF sensor, the IAC valve, plugs, wires, cap, rotor, and ignition coil. The only code is for MAF sensor voltage to high. I checked the wiring and I'm getting 12.1 volts to the MAF witch is good. I need HELP!!!!!!!!!!!
Holy cow it's a 20 year old car. It could be almost anything. What about PCV Valves? Throttle body? Engine mounts? Does it have a gasket leak? It could even be that the motor is just flat give out. Good luck with it.
As for O2 to MAF voltage I'm not totally informed. But I was going to ask if the MAF has been cleaned/replaced, how are the O2 sensors?
And of course, have you cleaned the throttle body? And is the fuel filter plugging?
Just taking a shot.
I wonder I'd had very similar problemms with my 07 , changed filter cleaned injectors plugs nothing😡 turned out after a lot more reading in was the sock on my fuel pump pick up , it was so friggen caked up . So I took it out cleaned it up put it back & I got like a 100 kilometer gain and problem disappeared . just another idea.
shudder
Hey guys thanks for your suggestions. I have sense replaced the throttle body. I found trash in the tank, so I replaced the gas tank and fuel pump and sock. I thought some trash might have got to the injectors so I replaced them to. The plugs are not showing a lean condition. I am totally lost.
The sock did not look clogged to me but like I said I went ahead and replaced the pump, sock, and the hole tank; no luck. Does any one know where I can get a wiring diagram for the MAF sensor wiring, I am still getting the MAF sensor voltage to high code.
Rando
Aug 25, 2021 11:12 AM
