Replacing some liecence plate bulbs
Old May 27, 2013 | 02:09 PM
ArmandoLuna's Avatar
Question Replacing some liecence plate bulbs
I started off by removing the cover for the lights on the outside of the car. And the whole socket and wire came out with it. The cover was on tightly. I wasn't sure if you take the cover off to change the bulb. I heard someone say take them out through the top. But I tried to get them off from inside the trunk and my hand is just too big to fit.
So a nice little guide would be nice for me to go by.
Oh. I drive a 94 stang
Old May 27, 2013 | 03:11 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
The bulb and socket twist out of the housing.
Old May 27, 2013 | 03:44 PM
So you do it from the exterior of the car?
Old May 27, 2013 | 04:07 PM
Bear Eats King...
Bear ****s Bone
Been a while since ive done it actually. But if I recall correctly there are screws holding the housing in. So you should get it from the outside
Old May 28, 2013 | 09:13 PM
1SloSix's Avatar
i use needle nose pliers and just get it from the interior.
Old May 29, 2013 | 12:35 AM
cntchds's Avatar
When I did it I pulled the housing down so the wiring/housing were hanging from the trunk, then I just twisted the bulb and pulled it out. I replaced it with LED's and they look a lot cooler than the stock halogen (or whatever) bulbs that have the warmer glow to them.
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
PonyMuscletang13
Sep 29, 2015 09:40 AM
AJ_Trevino15
Sep 28, 2015 07:51 AM
