Plasti dipped Mach 1 hood
Old May 14, 2013 | 08:34 PM
shurtual86's Avatar
Originally Posted by mdelao
when is the correct time to remove the tape??? i tried this when i painted the decklid but i had to use a cutter to separate the plastidip from the tape. i wouldn't like to do that to the hood.
I removed the tape about a min after the last coat.
Old May 16, 2013 | 10:09 PM
future9er24's Avatar
Originally Posted by mccolaus000
M. U could pull the tape up slightly where the plasty dip stretches and cut the stretched plasti dip without ever touching ur car with the blade. The plasti dip bungees back in place. Unless I miss understood
It doesn't quite work that well that way. Because its so stretchy, when to try and slice it when its not on a hard surface, it will just stretch more, and after it has been peeled, it doesn't like to stick back on (though some people online say the re liquefier thing works pretty well, but I've never used it personally so I cant say for sure). The best way is as mentioned above, peeling before its totally dry. Thats what I plan on next time (I X-acto'd on the car, good thing I have to do that so much already for school lol)
The exception being things like emblems, just spray all over those and peel when dry; the tight radius of the body panel to emblem will tear it pretty perfectly.
Old May 17, 2013 | 09:30 AM
mccolaus000's Avatar
I didn't have a problem doin it that way with a utility knife. Time consuming as hell but it worked
Old May 24, 2013 | 10:41 PM
Mach1Maniac's Avatar
Yeah if you have a area masked off and you plan to pull the tape off you would pull the tape off immediately after the last coat of plasti dip and always pulling the tape towards you(or else you won't get straight, smooth lines)
May 3, 2026 05:42 AM
yabutt
Oct 23, 2015 01:05 PM
TerryD
Sep 28, 2015 11:48 AM
seaclam
Sep 25, 2015 01:29 PM
tbear853
Sep 8, 2015 11:18 PM
