performance problems
Old Nov 20, 2007 | 06:35 PM
j-bird7684's Avatar
my 94 gt is running funny. it doesn't have the power that it used to. it's running like it's not getting enough gas or it's backed up or something. almost as if it's congested. please help me! i have a trick flow cold air intake, bbk headers, flowmaster exhaust.....don't know if that stuff will help you guys out. thanks for any info. please email me suggestions.
p.s. i just replaced the fuel filter.
Old Nov 20, 2007 | 06:41 PM
DynamicmustangGT's Avatar
might be that the fuel injectors need a cleaning if you havent done that before they have all sorts of gunk on them or it could be a spark plug. Hope that helps
Old Nov 21, 2007 | 12:05 AM
cntchds's Avatar
Have you ever replaced the fuel filter? It's simple and cheap. I'd try that.
Old Nov 21, 2007 | 02:37 AM
elcaminoguy's Avatar
Is it throwing any codes at all? I know that's going to be OBD1 but still should get some idea if it is.
What about the catalytic coverter?
If you can get the injectors out and cleaned it might help. Might want to check the EGR too.
Old Nov 21, 2007 | 05:42 AM
poldrv's Avatar
I would replace the fuel filter ( it should be done once a year) at the same time I would put in a bottle of Chevron Techron in an empty tank then fill it up. After you have run the car with a bottle of Techron in the tank you might have to repeat the procedure depending on how much crap is in your system, two bottles should work though. The key though is to put the Techron in an empty tank then fill with gas so that the Techron product will evenly dispurse. Also the CAI filter might have to be oiled or replaced. A tune up (new plugs) and a check of the EGR value might be benefical also.
Old Nov 21, 2007 | 05:56 AM
Miserable's Avatar
Had sort of the same problem. Mine was caused by stuff in my tank. I ended up replacing the fuel pump and filter. Also cleaned the injectors but do that as part of regular maintenance. I was throwing codes though.
http://forums.bradbarnett.net/showthread.php?t=72065
Old Nov 21, 2007 | 06:03 PM
cntchds's Avatar
I have a reader if your check engine light has been on. It would probably be cheaper than purchase. Let me know if you wanna borrow it.
Old Nov 21, 2007 | 07:26 PM
j-bird7684's Avatar
i've put octane booster, fuel treatment, and a bottle of lucas injector cleaner in it. it's not getting any worse so i'm thinking that it's either the injectors or the spark plugs. i've already changed the fuel filter and it didn't make a difference. there are no check anything lights comming on. oh, and it doesn't have any cats on it. i'm going to wait it out with the injector cleaner and see if that helps. i'll probably put another bottle in it after this tank of gas is used up just to make sure. thanks to everyone for your help. i'm still pretty new at this.
Old Nov 21, 2007 | 07:28 PM
j-bird7684's Avatar
also....how would i got about taking out the injectors and cleaning them? how difficult of a task is it? i can do the spark plugs, i just don't have a place or the tools to do it right now
Mpaps
Oct 11, 2017 08:06 PM
Evolution Performance
Northeast
Aug 5, 2016 12:46 PM
M3hunter
Sep 10, 2015 09:26 AM
Omegaprime92
1994-2004 V-8
Sep 8, 2015 08:53 AM
