How to install 7.5 rear end in car?????
Old Apr 20, 2013 | 04:15 PM
bmw160's Avatar
How do you install a new rear end in a 96 v6 mustang?
Old Apr 20, 2013 | 04:32 PM
houtex's Avatar
I'm sure there's more to your question, but as asked...
Well... there's always googling for "ford 7.5 rear end swap 96 mustang v6":
https://www.google.com/#sclient=psy-...+94+mustang+v6
But a lot of those are for v6 to v8 swaps. Still, the information is valid, and basically boils down to:
Step 1: Remove old axle. Make notes on *everything* you remove.
Step 2: Install new axle. Using notes from above, it should bolt right up and work.
Provided, of course, you have the same body style mounting axle.. nominally a '94-04 V6 Mustang axle, but variances do happen.
And that also assumes you're putting in another of the same axle. The swap to a v8 one is therefore covered with the googling.
Good luck!
Old Apr 25, 2013 | 11:03 PM
bmw160's Avatar
So it's a basic bolt in? How long should it take?
Old Apr 25, 2013 | 11:17 PM
1999Pony's Avatar
Takes me about an hr to swap rears. I've done it a couple times but its pretty basic.
Drop the driveshaft
Unbolt shocks
Unbolt upper and lower control arms
Remove springs
Reverse for install of new rear.
Fully bolt on and very easy
I can remember the driveshaft bolt sizes, but for everything else its a 15mm or 18mm I do believe.
Id say it count on 2 to 3 hrs max...
Old Apr 26, 2013 | 09:44 AM
bmw160's Avatar
What type of socket do you need for the drive shaft bolts?
Old Apr 26, 2013 | 12:57 PM
1999Pony's Avatar
I wanna say its a 13mm, and make sure its a 12pt socket, the 6 will slip.
Old Apr 26, 2013 | 05:06 PM
bmw160's Avatar
Ok thank you I'm gonna try to put it in on wendesday
Ecostang
Nov 3, 2022 08:50 PM
chadh92
Jul 29, 2015 06:56 AM
Ecostang
Jul 11, 2015 09:06 AM
Kev006
Jul 8, 2015 05:29 AM
