Grinding noise in rear
Old Jan 15, 2015 | 05:30 PM
toshgiles's Avatar
Hello, I have a 2000 Mustang (101k miles, second owner) that has a grinding noise coming from the rear. The sound is constant and unchanging in all speeds.
Here is where I haven't been able to find help via web searches: the sound stops when the clutche is in. I can coast almost silently.
When I had a shop look, they said it was likely the differential but that it could be anything from a small fix to a huge problem. They also couldn't tell me if the $1300 they quoted would even be the problem, or if it was a host of other problems.
Thank you in advance for your help.
Old Jan 18, 2015 | 10:31 AM
toshgiles's Avatar
Did I post this in the correct forum?
Old Jan 18, 2015 | 11:06 AM
Sure its not the throw out bearing? They usually stop making noise when you put pressure on them (putting the clutch in/to the floor).
Old Jan 18, 2015 | 12:38 PM
houtex's Avatar
Agreed. If it goes away when the clutch is pressed in, it's likey the throwout bearing.
The best thing to do is to get it on a rack and have it checked out.
Good luck!
Old Jan 18, 2015 | 12:49 PM
lowblustang00's Avatar
If it was the differential, I would think it would be speed related, and would do it wether you had the clutch pressed or not. Just my $.02
Old Feb 13, 2015 | 09:34 AM
RufusT's Avatar
It does sound like it could be in the differential. If you are sure it's coming from the rear, it is likely your differential input/output bearing. When the clutch is in, there is no load on the bearings and they will spin without the grind sound.
To determine the location, jack up the rear of the vehicle put it in gear and use a diagnostic stethoscope. I'll bet when you touch the diff, you hear lots of sound... not too bad to fix, but does take a good bit of work.
RufusT
Mr. V
Dec 24, 2016 02:57 PM
Fords4Ever
Oct 30, 2015 09:07 PM
Sep 16, 2015 06:44 PM
oldnjguy
Sep 10, 2015 02:39 PM
robjh22
Sep 8, 2015 12:31 PM
