ENGINE PROBLEMS NEED HELP
Old May 29, 2013 | 08:31 PM
rodsoccer2's Avatar
Alright right now my current engine had a problem and I can't figure it out. Idk if its something simple or something major. Whenever I slow down to say go around a corner and then give it gas it just falls on its face like its going to die and then I have to feather the pedal to get it going again. I have no clue what's wrong and I'm hoping you guys can help me out.
Old May 29, 2013 | 08:36 PM
shurtual86's Avatar
Check the battery connections, had a similar problem with my surburban, then it started doing that whenever I hit a bump. Turned out the wires for the battery terminals were loose.
Could also be the fuel pump, any CEL?
Old May 29, 2013 | 08:41 PM
rodsoccer2's Avatar
It's not the battery, because I just replaced that. Ill get a new fuel pump, ill need one anyway for my new engine.
Old May 29, 2013 | 08:46 PM
1999Pony's Avatar
Check your fuel filter as well.
I think its just pissed, it knows its being replaced.
Old May 29, 2013 | 08:53 PM
rodsoccer2's Avatar
While we're on the subject, what kind of fuel pump will I need to get for the new engine?
Old May 30, 2013 | 06:27 AM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
1 what do you keep your fuel level at?
2 why a new engine?
3 you can still have poor connections new battery or not...
Old May 30, 2013 | 06:44 AM
shurtual86's Avatar
Originally Posted by texastboneking
2 why a new engine?
He's adding two superchargers....
https://themustangsource.com/f635/ru...argers-519434/
Old May 30, 2013 | 06:49 AM
Bear Eats King...
Bear ****s Bone
Then I would say to that he needs a fast flowing pump. Svt focus pump is what alot of guys go with if I recal correctly. Its cheap and can put some fuel out
Old Jun 1, 2013 | 01:09 PM
shaunrc's Avatar
Ok when it comes to mods like this it is important to consider everything if one thing is off you may actually lose power and im talking about exhaust pipe size what type of headers how what size injectors what size fuel pump fuel rails intake manifold bottom end cause the stock one is only safe at 400 to 440 depending on how its been treated now how to get that power to the ground ? Rear end drive shaft and trans if you want reliability you have to spend money horsepower = money and getting it to the ground even more
Old Jun 25, 2013 | 10:20 PM
Sixpac's Avatar
I had sensor problems on my 93 when I got the problems you described.. I changed the MAF ATS AIC and it was good
Old Jun 27, 2013 | 12:46 PM
rodsoccer2's Avatar
When we swapped my fuel pump we found out my factory in tank fuel lines had holes in them so we replaced them with new ones and it works fine now!
Old Jan 10, 2014 | 08:09 PM
GottaHaveIt's Avatar
If using an aftermarket air cleaner could be that your MAF sensor got dirty that would maybe do it , kinda sounds like what I went through a while back.
Mpaps
Oct 11, 2017 08:06 PM
mustangsally_
Sep 18, 2015 05:35 AM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
Mrmiles1369
Sep 11, 2015 07:23 PM
Evil_Capri
Sep 11, 2015 08:39 AM
