Engine Firing Problem
Old Jul 12, 2007 | 06:17 AM
GTStang01's Avatar
i have a 01 4.6 gt that is running like crap. i have put new plugs in it and new air and fuel filter. i gapped the plugs as well, but it still is not firing correctly. it feels like one of the cylinders is missing i would say 2 or 3 times a minute but i can only feel it in lower RPM's, it may just be covered up in the higher RPM range though. Also the car has 67,000 miles on it. Any suggestions on this problem? Thanks in advance.
Old Jul 12, 2007 | 07:11 AM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
First off, make sure all of your coil packs are plugged in (ya know the black boxes on top of the spark plug). You may have one going bad so if you can get a code scanner somehow on it, it might tell you which one, especially if theres a check engine light.
Old Jul 12, 2007 | 07:53 AM
CircuitBreaker's Avatar
If your not getting any check engine light, I would see if you can find someone to datalog it for you with a SCT X-Cal or some Autotap software(used it several times). That will show you where the miss is.
If I had a plug not firing on the S-10 I had, the CEL light would flash.
Old Jul 12, 2007 | 11:55 AM
97svtgoin05gt's Avatar
Coils packs leak on these. It's a common problem. Get yourself either new stock or Accel coil packs. You should even feel a little performance increase if you go Accel.
Old Jul 12, 2007 | 12:58 PM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
Interesting, I didnt know anyone had made an aftermarket replacement coil on plug for the 99+ cars. I knew they made for the 96-98 with the dual coil packs, but these look kinda cool.
http://store.summitracing.com/partde...5&autoview=sku
Mpaps
Oct 11, 2017 08:06 PM
mustangsally_
Sep 18, 2015 05:35 AM
