Cleaning my IAC
Old Jan 31, 2006 | 11:23 PM
Mestizo's Avatar
Ok......the Haynes manual....is worthless here. I wanna check my IAC, but they show where it is on a 5.0 and 3.8.
Below I have a picture.....I understand what the IAC itself looks like and how to clean it....however when it's attached I cannot locate its position. Is it where the blue arrow is or the yellow arrow...or am I way off today?
I figured....by the yellow because the manual said I'll be removing 2 bolts. However....after giving it a second look the blue looks possible also.
If it's the yellow anyone know the size of bolts off the top of their head....because none of my wrenches are that small.
Old Jan 31, 2006 | 11:24 PM
Mestizo's Avatar
I should add......do I need to disconnect the battery to check this?
The manual really didn't make it clear.
Old Jan 31, 2006 | 11:30 PM
joker's Avatar
It is the one with the yellow arrow pointing to it in your picture, the one with the blue arrow is your Throttle Position Sensor. Dont mess the with the blue one or you could have issues.
Disconnect the hose and sensor plug with the yellow arrows pointing towards them. Then remove the two bolts holding it on, where the blue arrows are pointing. You should then be able to pull it off of the upper intake plenum.
As far as the bolt size, maybe a 6 or 7 mm?
Old Jan 31, 2006 | 11:33 PM
joker's Avatar
When removing any kind of eclectrical connection it is never a bad idea to disconect the battery. Just remove the negative battery cable, then get in the car, turn the switch over and press the brake pedal. This will ensure that all power remaining in the system is drained out. Now, just to disconnect the sensor, I probably wouldnt bother disconnecting the battery, but it should not hurt anything by doing so if you want to.
Old Feb 1, 2006 | 08:47 PM
Mestizo's Avatar
Coolio.....just need a sunny weekend.
Old Feb 3, 2006 | 06:03 PM
Valentino's Avatar
I have a strong feeling those bolts are 10mm, 6 or 7 seems way too small but I may be wrong. If you're going to clean your IAC you might as well take your air intake tube off and clean the throttle body and butterfly in there. I prefer GumCutter 2+2 brand carb cleaner, for whatever thats worth...
Road_Runner
Sep 2, 2024 04:46 PM
PonyMuscletang13
Sep 26, 2015 02:33 PM
dave07
Sep 6, 2015 12:24 AM
