Car Won't Start... Ticking?
Old Jul 1, 2011 | 07:34 PM
cntchds's Avatar
So yesterday I went out to my car, turned the key, and... Ticking? Not a click like the solenoid, a constant clicking from behind the dash. When I let go of the key, the light and the radio didn't come back on, and the only thing on in the car was the blinking Theft light and whatever was making the ticking before seems to be on whenever there is anything pulling current. Close the door with the key out and the ticking goes away though. I replaced the battery today, and the exact same thing happened when I turned the key. Ideas?
Old Jul 1, 2011 | 08:20 PM
starter would be the only other thing I could think of. Check the COP's and whatnot as well. Starting the car only has so many parts.
Old Jul 1, 2011 | 08:26 PM
Autotooner's Avatar
My C/T is cooler than Arin is.
my mark 8 did that one day. I just shut the switch off & back on & it quit. My ticking was coming from the driver's quarter panel tho. I suspect it was from the antitheft system. If you have a spare key, try it.
Old Jul 1, 2011 | 11:10 PM
cntchds's Avatar
I read elsewhere that someone had to have the entire antitheft system replaced..
Old Jul 2, 2011 | 02:38 PM
bluethunderhorse's Avatar
Take the car to a dyno shop and they can tune the theft system out of the ECM
Old Jul 3, 2011 | 04:51 PM
Onesickstang01's Avatar
Its called PATS. I always turn iy off on my cars. There is a ring behind the ignition that senses a chip in your key. Pretty common failure on fords and it makes it seem like bad fuel pump. Basically it cits fuel system off as part of theft deterent. Its worth it to turn it off
Old Jul 3, 2011 | 05:24 PM
HOSS429's Avatar
legacy Tms Member
and you wonder why us old codgers yearn for the day of points and carbs ..
Old Jul 3, 2011 | 11:01 PM
cntchds's Avatar
I made a completely dark video, but hopefully it will at least get the point across. It is not the starter, it is not the battery, it is not fuel or spark. The car just acts like the battery died, except it keeps the THEFT light blinking. I have tried to jump start the car with my brother's car, to no avail. Exactly the same result. I have not tried to push start it, though, for fear of pushing it down the street, just to have to push it back...
Old Jul 7, 2011 | 04:20 PM
cntchds's Avatar
1 part baking soda, 4 parts water, 100 parts ego, let cables sit for 5 minutes. Presto.
Old Jul 8, 2011 | 10:11 PM
just a thought...you tried to change the LED's in the instrument panel, could it be something from that possibly?
Old Jul 9, 2011 | 10:46 AM
cntchds's Avatar
The negative battery cable was corroded. I soaked it in baking soda, and all was good in the world again. Thanks guys.
Jim74656
May 1, 2023 02:15 AM
jc46002003
Apr 15, 2016 03:00 PM
Mackitude
Aug 13, 2015 01:05 PM
Coyote5-0
Aug 2, 2015 08:38 AM
