Camber bolts
Old Dec 13, 2012 | 01:04 PM
mdelao's Avatar
Camber bolts
What do you guys think about these bolts?
http://www.americanmuscle.com/eibach...olts-9404.html
I have the SR springs, and now have a negative camber, not planing to spend money on caster camber plates, would these bolts be enough?
Old Dec 13, 2012 | 02:27 PM
AMDanBailer's Avatar
Former Vendor
Yes those Camber bolts will do the trick! The SR Performance springs lower you car about 1.5in' all the way around, so the camber/toe shouldn't be off to bad.
Throw in a set of Camber Bolts then get it aligned and you'll be in good shape!
I hope this helps. Let me know if you have any questions!
-Dan
Old Jan 2, 2013 | 01:51 PM
mdelao's Avatar
Just take my car to shop to install the camber bolts and realign, not problems at all just saw how the mechanic came in to the office to ask about the bolt to his boss, I wasn't aware if there is something wrong. Finally they call me to tell that car was ready. I just realized that negative camber had gone, until this morning. I went to check if there were something wrong, I found what is wrong. The stupid mechanic did not install the alignment the washer (the one is used to adjust the camber position). Camber is just the same than before just like the way it used to look with stock bolts
Is there any chance that something is damaged down there?
FromZto5
Sep 30, 2015 05:28 AM
AJ_Trevino15
Sep 28, 2015 07:51 AM
Stephen Laslo
V6
Sep 18, 2015 07:57 PM
