99 to 04 Mustang GT Manual OSS and Reverse Lamps
Old Dec 8, 2025 | 08:40 AM
02SStang's Avatar
On the 99 to 04 Mustang GT there are two wires to the OSS (Output Speed Sensor) on the transmission. There is a Gray with Red stripe and a Green with White stripe. I am doing some testing on my T56 swap for the T3650. Should any of these wires have any voltage when the key is on or does only the OSS provide current when the wheels turn?
For the reverse lamps there are two wires. The power source is the orange wire and the Black with Pink stripe is the output signal to the reverse lamps. When testing I was able to confirm the Orange is providing power. When I jumped the Orange to the Black with Pink stripe the lights did not go on. Is this the correct test or am I missing a step.
For both of the above, I am testing all circuits prior to connecting the plugs and putting the harness back on the new T56.
Old Dec 8, 2025 | 11:39 AM
05stangkc's Avatar
Welcome,
I Pulled A Couple of Things out of The 2002 Shop Manual.
Sorry All I Got on Your Questions!
Looks Like Maybe Some Read Between The Lines Info!
KC
File Type: pdf
File Type: pdf
Old Dec 8, 2025 | 12:14 PM
02SStang's Avatar
Thank you. I will look these over.
Combs1995
Dec 18, 2022 03:29 PM
coolkilled
May 28, 2015 06:43 PM
RichCooper
'10-14 Exterior Modifications
Sep 18, 2012 07:22 PM
HOTLAP
Feb 6, 2005 08:32 PM
steal101
05-09 Exterior Modifications
22
Dec 27, 2004 12:00 PM
