95 gt cutting out
Old Sep 25, 2012 | 12:21 PM
freaknasty's Avatar
95 gt cutting out
Started cutting out almost like out of gas or missing real bad . But it's intermittent no rhyme or reason when it's going to do it . Hot , cold , cruising , firing it up flat surface , uphill or downhill . Found loose wire on alternator ( it was arcing bad ) but fixed that thought I solved problem but it's still doing it . Might be fine for a whole day or not totally random !!!!!!!
Old Sep 25, 2012 | 12:59 PM
AlsCobra's Avatar
A Man Just Needs Some....
Fuel filter first. Check for possible water in the old one also.
Old Oct 5, 2012 | 01:07 PM
freaknasty's Avatar
Change filter and bumped up pressure still problems . Very random !!!!!!!!
Old Oct 9, 2012 | 12:56 AM
White94GT's Avatar
Bad fuel injector/s?
Old Nov 10, 2012 | 11:15 AM
Lev's Avatar
Lev
Have you checked engine codes? If it shuts off completely it may be a fuel pump.
Feb 10, 2017 07:12 PM
irobles
1994-2004 V-8
Sep 20, 2015 04:30 PM
samjluck
Sep 17, 2015 10:24 PM
