94 gt gears gave out :(
Old Jan 3, 2013 | 02:58 PM
jacqui361's Avatar
Yep. Gave out. Need a whole new rear end. Anybody know what a decent estimate range should be to replace it with used parts? Btw, this is my first mustang and my baby
Old Jan 4, 2013 | 01:56 PM
stupidgenius36's Avatar
Just Plain Rude!
If the gears stripped, I'd think you only need new gears. Why do you think you need a whole new rear end?
Old Jan 4, 2013 | 02:17 PM
AlsCobra's Avatar
A Man Just Needs Some....
Yep. Find out exactly what you tore up. Tear down and see what's broken. Carriers are expensive but ring and pinion are not that bad. Labor is never cheap unless you can find a good tech to build it on the side.
Old Jan 5, 2013 | 06:03 PM
jacqui361's Avatar
The shop guy just said he was gonna need a rear end cause its "pretty tore up and wore down". I can believe it because it's almost 20 years old and nothing has been replaced/fixed back there. I'll get details from as soon as I can.
Old Jan 5, 2013 | 06:43 PM
cntchds's Avatar
Probably much cheaper to just buy a rear end that is already built the way you want it with the gears you want.
Old Jan 6, 2013 | 10:52 AM
cpotts13's Avatar
Check out mps auto salvage in eBay. They sell complete rear ends for every mustang. Each read end is inspected re sealed, new bearings etc. Etc. They're painted black and look nice too. Expect to pay $700-$900 but they're ready to bolt on.
Old Jan 7, 2013 | 09:09 AM
Poisoned Pony's Avatar
A local salvage yard should have a rear end for cheap. The 8.8 is a dime a dozen. I just worked on a Crown Vic who's axle seal went out and emptied the rear of enough fluid to dry out the bearing. Axle destroyed the bearing, the axle tube on the rear end, the e-brakes and brakes and smoked the differential. We acquired a rear from a local salvage yard for $375 and freshened it up with new seals.
Old Jan 7, 2013 | 09:48 AM
cpotts13's Avatar
http://www.ebay.com/itm/94-95-MUSTAN...07a6d3&vxp=mtr
http://www.ebay.com/sch/i.html?_saca...ear+end&_sop=3
At least wih these you can upgrade to a better gear ratio at the same time..
iliveonnitro
Oct 7, 2021 06:31 PM
Rando
Aug 25, 2021 11:12 AM
cameron2581
'10-14 Interior and Audio
Nov 26, 2015 01:26 PM
Rando
Sep 30, 2015 12:28 PM
DarrenGT
Sep 19, 2015 01:00 PM
