3 inch Lowering
3 inches and you'll be dragging the ground. 1.75 is as low as I'd go. That's where I'm at, and I'm scraping speed bumps and driveway transitions on a regular basis.
Yeah, I think mine is around 1.5" to 2" lowered, speed bumps are a definite no no. I'd like to make it lower, but then there's no way I could get in my driveway.
1 Post
Originally Posted by rodsoccer2
I'm not going to get it lowered, after you guys's inputs and some research it's not worth it, I spent my money on some new dual exhaust.
1 Post
Is 500$ too much to have it lowered 2 inches all the way around?
1 Post
Sounds good, the guy told me 500$ for springs and labor! I still don't know if I want to do it though.
I wouldn't go for that. Install is pretty easy and straight forward as long as you know how to turn a ratchet.
A couple years ago, I was quoted 1100 for labor to do shocks and springs. Now I know that's somewhat high, but just to give some perspective. It sounds to me like the guy is either buying some really crappy/cheap springs, or more likely cutting your stockers.
Thanks everybody for your inputs! I'm not
Going to do it right now, maybe later. I'm
Going to go for engine swap. I would go up to the 4.6L but I don't think it has the power that I want. Any crate motor or other engine options you guys would recommend?
1 Post
