3 inch Lowering
Old Jan 24, 2013 | 09:01 PM
rodsoccer2's Avatar
3 inch Lowering
Hey what are you guy's thoughts on lowering SN95's? I'm thinking about doing it but I just don't know.
Old Jan 24, 2013 | 09:37 PM
shaunrc's Avatar
If you do you will need caster camber plates or your car will not be able to be aligned properly depending on how low you go
Old Jan 24, 2013 | 09:40 PM
3 inches and you'll be dragging the ground. 1.75 is as low as I'd go. That's where I'm at, and I'm scraping speed bumps and driveway transitions on a regular basis.
Old Feb 2, 2013 | 03:24 PM
Vader99's Avatar
Yeah, I think mine is around 1.5" to 2" lowered, speed bumps are a definite no no. I'd like to make it lower, but then there's no way I could get in my driveway.
Old Feb 2, 2013 | 07:05 PM
rodsoccer2's Avatar
I'm not going to get it lowered, after you guys's inputs and some research it's not worth it, I spent my money on some new dual exhaust.
Old Feb 2, 2013 | 07:17 PM
1999Pony's Avatar
Its completely worth it. When coupled with new shocks and struts the car will ride, handle and look a lot better.
Old Feb 2, 2013 | 07:35 PM
Vader99's Avatar
I agree, it's totally worth it. Just don't lower it 3"
Old Feb 3, 2013 | 10:37 AM
Black03Mach1's Avatar
The normal lowering is 1.75, I've seen a 1.75 drop and the car had 18s on it and it had a better look. Maybe consider that?
Old Feb 3, 2013 | 10:54 AM
cpotts13's Avatar
3 inches is way to much. I am lowered 2 inches all the way around with H&r super sports and I have to watch out for clearance everywhere.
Old Feb 4, 2013 | 07:26 PM
rodsoccer2's Avatar
Is 500$ too much to have it lowered 2 inches all the way around?
Old Feb 4, 2013 | 07:37 PM
cpotts13's Avatar
Yep. $250 for the springs should be all.
Old Feb 5, 2013 | 05:40 AM
1999Pony's Avatar
That sounds about right without labor. Your probably gonna want shocks/struts when you get springs. If you don't, ride quality will suffer, handling will suffer, and eventually your gonna need to get new shocks/struts because you currents ones life span will be greatly decreased.
Old Feb 5, 2013 | 02:17 PM
rodsoccer2's Avatar
Sounds good, the guy told me 500$ for springs and labor! I still don't know if I want to do it though.
Old Feb 5, 2013 | 03:57 PM
cpotts13's Avatar
NO! Buy your own springs, get new shocks and struts and do the labor yourself. You will need new shocks and struts. You will regret not doing it..
Old Feb 5, 2013 | 05:36 PM
1999Pony's Avatar
A couple years ago, I was quoted 1100 for labor to do shocks and springs. Now I know that's somewhat high, but just to give some perspective. It sounds to me like the guy is either buying some really crappy/cheap springs, or more likely cutting your stockers.
I wouldn't go for that. Install is pretty easy and straight forward as long as you know how to turn a ratchet.
Old Feb 5, 2013 | 07:00 PM
cpotts13's Avatar
This.
Old Feb 5, 2013 | 07:02 PM
rodsoccer2's Avatar
Thanks everybody for your inputs! I'm not
Going to do it right now, maybe later. I'm
Going to go for engine swap. I would go up to the 4.6L but I don't think it has the power that I want. Any crate motor or other engine options you guys would recommend?
Old Feb 5, 2013 | 07:04 PM
1999Pony's Avatar
First question, do you live in a inspection/smog state?
Old Feb 5, 2013 | 07:06 PM
einstr's Avatar
so how hard is it to install springs, struts and shocks? what special equipment is needed?
Old Feb 5, 2013 | 07:48 PM
1999Pony's Avatar
Jack and jack stands
