1998 Mustang Camshaft position sensor problems/misfire
Old Jul 29, 2015 | 09:13 PM
STOERKEL's Avatar
Whenever we read for codes through the computer of the mustang we get this code: P0340
We replaced the camshaft position sensor because the sensor the car came with originally was melted onto the synchronizer. We replaced the synchronizer as well. The car is also not running on all 6 cylinders, we narrowed it down to the second cylinder. We checked the compression and it was good, we checked the spark plugs and it was good. Could the camshaft position sensor be the problem with the misfire?
Also, the car has been overheating a bit, whenever I'm driving I hear like a long grasshopper sound, and when I try to turn the cars ignition it has trouble turning on, like a loss of power. Please help me diagnose these problems. The engine itself it running very strong when revving it.
Old Aug 26, 2015 | 05:30 PM
Bigdeputy's Avatar
Injector?
Old Aug 26, 2015 | 06:29 PM
Replace the alternator. It sounds weird, I know, but I had those codes, changed that sensor, spark plugs, tested the injectors, cleaned the MAF and TB, hell, I even replaced the cars computer. A 5 minute job to replace the alternator and I haven't had any problems since.
Old Sep 11, 2015 | 11:38 AM
Jim74656's Avatar
Agreed, also check/replace the battery, again I know it sounds very strange but the battery is the alpha and omega of your charging system and if it's going bad it can also produce weird issues. I know you stated that the battery is a month old but the alt can also cause batteries to go bad depending on how long it's been bad.
When it comes to the electric system of a car having a good battery is key.
Michael Follett
Jul 24, 2015 06:58 AM
trackpack13gt
Jul 23, 2015 11:13 PM
Jul 17, 2015 05:40 PM
