Woodview inserts
Old May 23, 2005 | 04:53 PM
2Slack's Avatar
Has anyone successfully removed their Woodview inserts? Did they leave a sticky residue or did they just come right off?
Old May 23, 2005 | 05:12 PM
38special's Avatar
I removed the stereo piece because it got cut with a razor when opening the box. Installed it and ordered a replacement. When the replacement came in... Yanked it off no problem. Made sure to get a good grasp on it without scratching anything, then yank! It is just 3m tape. I'm sure a hot temp in the car helped me though.
Old May 23, 2005 | 05:23 PM
2Slack's Avatar
So it didn't leave the stereo sticky?
Old May 23, 2005 | 05:28 PM
38special's Avatar
No sticky left behind. Who knows if that would change if it was removed after a year or two vs. three weeks?
Old Feb 9, 2006 | 10:50 AM
2Slack's Avatar
<div class='quotetop'>QUOTE(2Slack @ May 23, 2005, 5:56 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
I just wanted to revisit this question. I may really need to remove some parts of my Woodview pieces. Has anyone remove them after they had been installed for a long time. Was there a residue left from the 3M tape and what would be best to clean it?
Old Feb 9, 2006 | 08:40 PM
hawgman's Avatar
Did you use the adhesion promoter, or just stick them on?
Old Feb 10, 2006 | 06:24 AM
2Slack's Avatar
<div class='quotetop'>QUOTE(hawgman @ February 9, 2006, 10:43 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
It is just stuck on. I got an early kit before they were sent with the adhesion promoter.
Old Feb 10, 2006 | 07:16 AM
hawgman's Avatar
Then I would think that they should just peal off. If there is any "sticky" left, could probably wipe it down with a rag and alcohol.
Old Feb 10, 2006 | 08:25 AM
2Slack's Avatar
<div class='quotetop'>QUOTE(hawgman @ February 10, 2006, 9:19 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Thanks, I just heard from Woodview. They suggested heating with a blowdryer, them wiping with goo-gone and then alcohol.
Mar 30, 2021 09:29 AM
tukatz
Off-Topic Chatter
23
Oct 20, 2015 09:54 AM
Sep 16, 2015 06:44 PM
Sep 1, 2015 01:19 PM
