Where to buy IPOD plug for 07+ mustang?
Old Sep 6, 2008 | 11:06 PM
buffguy's Avatar
Hey guys where can I buy the wire to connect my IPOD to the socket in the center console?
Old Sep 7, 2008 | 12:22 AM
Ministang's Avatar
If you are just planning to use the headphone output of the iPod to connect to your aux-in jack, all you need is a cable with 1/8" stereo plugs on each end. Radio Shack carries them, and any store like Walmart should have them in the iPod/MP3 accessories section. There are many places to buy them online too, but often shippping would be as much as the cable itself.
Old Sep 7, 2008 | 12:24 AM
Shelby10''s Avatar
Radio shack...wallmart...best buy....Ultimate electronics...You name it they got it.
Old Sep 7, 2008 | 06:22 PM
Cobrakev's Avatar
I have tried to use that jack with my ipod. It only plays music out of the driverside speakers. Anybody else have this problem?
Old Sep 7, 2008 | 07:15 PM
Ministang's Avatar
Have you tried a different patch cable? Sounds like your cable or one of the plugs may have a short somewhere, not uncommon for the little 1/8" patch cables. It is possible it is a problem with the aux jack in the car itself, but I'd try another cable or two first. I'm assuming you can hear both channels just fine with headphones out of the iPod?
Old Sep 7, 2008 | 07:43 PM
Five Oh Brian's Avatar
Cobrakev: Bought mine at Radio Shack, but you have to be sure it is a stereo cable, and not just a mono cable, or else only one side plays.
Old Sep 7, 2008 | 07:54 PM
Ministang's Avatar
The easy way to tell if the cable is stereo and not mono is the stereo plug has the metal part of the plug into three sections, the mono plug is divided into two sections.
Old Sep 9, 2008 | 02:51 PM
DarkFireGT's Avatar
For better sound, pick up one with a dock connector on one end and 1/8" (3.5mm) on the other end. You can get it from Amazon for about $10. You can't charge at the same time, but it sounds a lot better.
Old Sep 11, 2008 | 09:12 AM
jedikd's Avatar
what you want is one of these:
http://cgi.ebay.com/BELKIN-Auto-Car-...QQcmdZViewItem
plus one of these:
http://cgi.ebay.com/3-5MM-6FT-MALE-H...QQcmdZViewItem
Spend less than $20, you'll get superior sound out of the dock connector versus the top connection, and you'll charge the ipod. I usually avoid buying anything cable related at best buy or those kinds of places, they make a killing on overcharging you for that stuff.
Only downside is that if you put your ipod in the center console, difficult to change/view songs. So if you feel like doing a little bit of work, pick up one of these for $20
http://www.amazon.com/Harman-Kardon-...1146024&sr=8-1
Installed mine myself in an hour and it works great. I put the controller by the shifter, screen in between the vents, and I can operate the ipod safely while still keeping my eyes on the road.
Old Sep 12, 2008 | 08:48 AM
buffguy's Avatar
I thought you could use the radio's button to control the IPOD? How does the belkin plug work? Where would you stick the stereo cable to? Inside the stereo socket on the belkin adapter?
plus one of these:
Old Sep 12, 2008 | 09:26 AM
jedikd's Avatar
you can't use the radio buttons to control the ipod unless you get something like "triptunes", at least $100+.
With the belkin adapter you would connect the 3.5mm cable from the port on the charger part to the audio in, which is easy since there's a cigarette lighter right next to the audio plug in the center console.
With the belkin adapter you'll need to still use the ipod controls. I put the ipod in the center console and bought a cheap remote for the ipod, to control volume and skip songs and velcroed it next to the shifter.
Eventually I got rid of all that and now use the Harman Kardon Drive + Play.
Old Sep 12, 2008 | 10:29 AM
StangRalle's Avatar
try www.mp3yourcar.com
Old Sep 12, 2008 | 03:27 PM
buffguy's Avatar
That would be annoy to have to change songs using the Ipod and not the radio controls. Is it hard to install trip tunes?
Old Sep 12, 2008 | 04:50 PM
USMC0341's Avatar
I used this....http://cgi.ebay.com/ebaymotors/2008-...6919QQtcZphoto
It's worked great so far and with no problems.
Jim74656
May 1, 2023 02:15 AM
Jul 20, 2015 06:26 AM
Ecostang
Jul 11, 2015 09:06 AM
Mustang1987
Jul 8, 2015 11:21 AM
