Steeda tri ax shifter
Old Dec 17, 2011 | 09:12 PM
nicu7's Avatar
Will the stock shifter **** fit this? 2006 GT
Old Dec 17, 2011 | 09:16 PM
cpotts13's Avatar
It should.
Old Dec 18, 2011 | 08:58 AM
Tbar's Avatar
Don't think it will fit. Stock threads are 12mm x 1.25 most aftermarkets are 12mm x 1.75.
Old Dec 18, 2011 | 09:03 AM
nicu7's Avatar
Okay thanks.
Old Dec 18, 2011 | 09:09 AM
cpotts13's Avatar
Maybe. ..
O got a short throw shifter and my factory shift **** fit just fine..
You should just get the combo kit from am (shifter and ****). Its only a couple dollars more.. just in case.
Old Dec 18, 2011 | 12:28 PM
silversky545's Avatar
Im trying to decide between steeds or mgb or whatever it's called.... Will my hurst arm fit either one of these?
Old Dec 19, 2011 | 11:34 AM
tj@steeda's Avatar
Yes the stock shifter *** will fit the Steeda Tri Ax.
Oh by the way. 15% off and free shipping is our current promotion on them.
http://www.steeda.com/store/ford-mus...-shifters.html
Not sure about the Hurst Arm.. Sorry.
TJ
Old Dec 19, 2011 | 11:41 AM
Doogie's Avatar
A Hurst arm will bolt right up to the Steeda (assuming you have a Hurst billet or comp shifter), but the MGW uses a totally different style arm and would require some modifications to work. Here's a thread with some details on how to modify the Hurst arm to work on a MGW... https://themustangsource.com/f692/hu...ersion-491509/
Jul 8, 2016 08:53 AM
Hristofor
1994-2004 V-6
Sep 11, 2015 12:05 PM
dbrinkley2008
Sep 9, 2015 07:02 AM
Sep 8, 2015 10:45 AM
Sep 2, 2015 07:33 PM
