Steeda Tri-Ax
Old Feb 27, 2006 | 04:31 PM
SVTJackl's Avatar
I would like to get a Steeda Tri-Ax Shifter installed but I hear that you must install it from the bottom of the car. Is this true? Or is thuis something I can do in my garage?
Old Feb 27, 2006 | 09:20 PM
Scott's Avatar
It is the same as the Pro 5.0 shifter that I have. I installed it in the garage with another person under the car to help a bit. It was tight, but I got it in through the top. I did not have to remove the driveshaft as some people have said that they have. It took me about 45 minutes total to install mine.
Hope this helps.
Scott
Old Feb 27, 2006 | 09:35 PM
SVTJackl's Avatar
That's not bad at all. I can probably get my son to help me out then.
George
Old Feb 28, 2006 | 10:47 AM
subzero05's Avatar
yes , it really takes 2 people to make it easiest and if you can get it up off the ground you are really in business. The steeda, Our B&M and the others all install generally the same way..
Old Feb 28, 2006 | 01:34 PM
SVTJackl's Avatar
Very Nice.....Thanks Guys. I'm just going to get the car up on jack stands then and have my son help me.
Old Feb 28, 2006 | 05:24 PM
dustindu4's Avatar
9 is not my lucky number.
check my sig
Sep 30, 2015 07:02 PM
GeoWett
Sep 30, 2015 06:40 AM
Sep 24, 2015 08:15 PM
Sep 16, 2015 06:44 PM
Sep 10, 2015 12:44 PM
