Shortened shift boot with Hurst stick
Old Dec 22, 2008 | 01:31 PM
Doogie's Avatar
I am about to install a Pro5.0 shifter with a chrome Hurst stick and am more than likely going to upgrade to a Redline boot. So was curious if anyone else with a Hurst shifter/stick has done this and if so, did you go with a shorter boot? And if you did, how much shorter?
Old Dec 25, 2008 | 06:23 AM
Scott's Avatar
I have the Pro 5.0 and a Roush stick and **** and am running the stock boot. I wouldn't go too much shorter than stock though, I think that stock fits pretty good.
Old Dec 25, 2008 | 10:38 AM
GRAYPNY's Avatar
Same setup as you and have the stick on the shortest holes. After you put the stock boot back on you are right at the bottom of where it says Hurst on the handle.
Old Dec 25, 2008 | 04:13 PM
302svt's Avatar
Any pics, I have this also but on the high setting as I didnt think it would work and still show the Hurst emblem.
Old Dec 25, 2008 | 04:20 PM
GRAYPNY's Avatar
Well since it's christmas here ya go.
Old Dec 25, 2008 | 04:40 PM
Doogie's Avatar
Rich, which trim ring do you have?? Yours looks like this one, but it gives me heartburn considering the $150 price tag!
http://www.partscheap.com/Mustang_Al...3z-7277-ba.htm
Old Dec 25, 2008 | 07:48 PM
302svt's Avatar
Thanks for the pic, I am going to lower mine tomorrow.
Old Dec 28, 2008 | 11:02 PM
polodinks's Avatar
thats the one same stock one that came on my car its nice but expensive
Old Dec 29, 2008 | 04:55 AM
partsbill's Avatar
I have the hurst shifter with the OEM Bullitt boot and bezel assy, it does not require the boot adapter grommet that came with your shifter, the boot fits tight around the shift lever.
Old Dec 29, 2008 | 06:56 AM
Doogie's Avatar
Originally Posted by partsbill
I have the hurst shifter with the OEM Bullitt boot and bezel assy, it does not require the boot adapter grommet that came with your shifter, the bot fits tight around the shift lever.
Cool. I just might have to make that investment as not having the rubber grommet along with the bezel does look sharp!
Gigantor
May 11, 2023 07:31 PM
Jul 8, 2016 08:53 AM
irobles
1994-2004 V-8
Sep 20, 2015 04:30 PM
dbrinkley2008
Sep 9, 2015 07:02 AM
