Shaker 1000: Maximum depth for replacement subs?
Old Apr 19, 2007 | 05:01 PM
chris_fowler99's Avatar
How much depth do I have to work with if I replace the stock Shaker 1000 subs?
Also, can I just drop-in replace them or are there amplification issues?
Old Apr 23, 2007 | 05:18 PM
wow...nobody?
Old Apr 23, 2007 | 05:26 PM
Infinity's Avatar
I will say they're dual voice coil (2 ohm, I believe), and someone dropped 10w3v2's in the box with no modifications, so they're at least 5.75" depth. I don't have one to measure.
Old Apr 24, 2007 | 10:09 AM
Hmm...I can possibly get a pair of these for $40, used. Wondering if it's worth it.
Details:
» 10" sub with dual 4-ohm voice coils
» suitable for marine use
» injection-molded polymineral cone
» double-stitched, foam-ribbed Santoprene rubber surround
» frequency response: 25-500 Hz
» power handling: 50-300 watts RMS
» peak power: 600 watts
» sensitivity: 85.5 dB
» top-mount depth: 5-9/16"
» sealed box volume: 0.8-3.0 cu. ft.
» ported box volume: 1.25-1.75 cu. ft.
» Recommended Q-Logic Box Type: 2
Old Apr 24, 2007 | 05:39 PM
Infinity's Avatar
$40 for the pair? Definitely worth it. Kicker makes very good stuff, they've just fallen out of favor for the internet "boutique" brands in the last few years. You'd be quite happy with those drivers.
Old Apr 25, 2007 | 11:09 AM
mustang_lurkers's Avatar
I replaced the shaker 1000 subs in my car and measured the maximum mounting depth at 5 and 1/4 inches. If you stick with the stock amps you will need to find dual voice coiled speakers. I used new amps with more power and am happy with the upgraded speakers in my shaker 1000 box.
Old Apr 25, 2007 | 03:07 PM
Well...if it doesn't fit...I'll just have to craigslist it.
Old Apr 30, 2007 | 01:44 PM
official_style's Avatar
does it make a big difference in sound to change the subs but keep the stock amps?
Old Apr 30, 2007 | 07:36 PM
Infinity's Avatar
The best answer I can give is definitely, maybe. You'd need to select subs that work well within very specific parameters, and then the performance would have to FAR exceed the factory drivers for any difference to be noticed as our hearing is very insensitive in the lower ranges.
So, yes, it can make a difference, but not very likely. Change the drivers AND the amps, and now we're cooking. That opens up millions of combinations.
Old Apr 30, 2007 | 09:31 PM
but thats too much work, and im pretty happy with how it sounds.
lakersfreak
Jun 13, 2022 12:29 AM
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
PonyMuscletang13
Sep 29, 2015 09:40 AM
