Replacing Shaker head unit
Old Apr 21, 2005 | 05:34 PM
hawgman's Avatar
I'm sick and tired of fighting with this Shaker1000 ( 4th one so far ) and considering a replacement. But, I do not want to go with a single din setup. I am looking at the Kenwood DDX7015 head unit. Anyone installed one of these in your 05 yet? Curious about the fit.
Also, anyone know of a source to get the factory harness plug from? Yes, I know the stock amps are junk. But considering the price of the Kenwood, plus the fact that I will most likely go with the navigation system also, replacing the amps is going to be down the road. So is using an aftermarket head unit witht he existing amps and wiring a possibility? Or should I plan on a complete new wire job?
Old Apr 22, 2005 | 02:40 PM
steve19970's Avatar
As far as double din is concerned, you'll have no fit issues...the Mustang DIN is way bigger than a double. Search a little bit...I know someone on here installed one of those.
I don't know about the harness...good luck!
Old Apr 23, 2005 | 12:26 AM
peet's Avatar
have a look at the new Pioneer AVIC D1 - it's a double din nav with realtime satellite-fed traffic overlaid on the maps.
$1100-1400 or thereabouts depending on dealer. Crutchfield now has a page up on the unit for your perusal.
Cheers
Old Apr 23, 2005 | 07:41 AM
Sonic Thunder's Avatar
Kenwood Rocks...owned many and never a prob. Currently have a single din in the Stang but your choice will work and if you order from Cruthfield you get the wiring harness and everything you need to do the job yourself..As with wiring harness...you will lose the woofer, or at least I did, but I'm running aftermarkets. Rumor is that a harness exists that will allow you to use you woofer..I have not seen it.
Old Apr 25, 2005 | 10:16 AM
hawgman's Avatar
Kewl guys. thanks for the replies.
duppycat
Feb 16, 2019 08:36 AM
OneCoolGT
Dec 10, 2015 07:55 PM
FromZto5
Sep 30, 2015 05:28 AM
earl610
Sep 7, 2015 11:57 AM
