Rearview Mirror Project
Old Jan 23, 2008 | 02:05 PM
07gtcs's Avatar
My photochromatic mirror does not work properly with tinted windows. The plan is to turn the compass button into an on/off switch to change from normal to dark. Haven't opened it up yet, but I'm assuming I'll bypass the photodetector by shorting the two wires and then running them through the compass button. Then I'll leave the compass function on all the time.
Has anyone tried this yet?
Old Jan 23, 2008 | 08:07 PM
GottaHaveIt's Avatar
hope you have a specs sheet on the mirror first ! that's like an $800.00 $ item at best.
Old Jan 24, 2008 | 06:05 AM
07gtcs's Avatar
Don't need the specifications on it. The photodetector should be pretty simple to identify. It's just a variable resistor that changes resistance by the light it receives. By either shorting or opening the wires, it will tint or clear the mirror.
I don't know where you got the $800 dollar price from...you can pick one up from eBay for as little as 30 clams.
Old Jan 24, 2008 | 04:52 PM
mikes rx's Avatar
I haven't tried it yet, but I've never had a problem with tinted windows and dimming mirror, neither on the mustang nor other cars. What's going on???
Old Jan 26, 2008 | 06:17 AM
07gtcs's Avatar
It's too slow to react to light changes. My eyes are very sensitive to lights at night. When it doesn't sense light, the mirror is clear...then it takes too long to darken. I would like to be able to control it manually.
Old Jan 26, 2008 | 06:53 AM
denlem's Avatar
Why not just find out how to adjust the sensitivity on the mirror? It seems that would be the best/easiest way to go.
Another thought... could the mirror be defective?
Old Jan 26, 2008 | 08:51 AM
Steved's Avatar
I agree, I notice it in both cars. Sometimes I have to turn the mirror away, because it just won't go dark. It might have something to do with driver height, mirror angle, and your eye sensitivity. My wife doesn't have a problem with it at all.
Old Jan 26, 2008 | 10:07 AM
mikes rx's Avatar
I just thought of another possible solution:
Maybe put a small piece of black electrical tape over the sensor on the back. It may react faster that way...I'm not sure.
Fedupdave42169
Oct 23, 2015 09:58 AM
AdPock
Sep 24, 2015 12:00 PM
MRGTX
Sep 16, 2015 08:08 AM
Earlsays
Sep 12, 2015 06:29 PM
