Rear Deck Speakers
Old Sep 28, 2011 | 05:50 PM
B1GP1MP1N's Avatar
Rear Deck Speakers
Has anyone replaced the speakers in the rear deck? If so, how difficult was the R&R?
Old Sep 28, 2011 | 06:03 PM
don't know about the install but I am interested in which speakers your looking to install. Thinking about this myself.
Old Sep 28, 2011 | 06:57 PM
B1GP1MP1N's Avatar
Really I haven't even looked at speakers yet. I did my door speakers because I had blown one of the OEM speakers. I just purchased some inexpensive 6x8s at Walmart. The install was simple
Old Sep 28, 2011 | 09:10 PM
05PRMTX's Avatar
i havent done it myself but pretty much all the panels in the back have to come off
Old Sep 29, 2011 | 05:55 AM
someone did a write up here a while back. He had pictures and all. I'll see if I can find it for you.
Old Sep 29, 2011 | 06:40 AM
B1GP1MP1N's Avatar
Wow that sucks! One of my friends has a new camaro and he said the same thing about his. Seems like they just aren't worth the effort.
Old Oct 1, 2011 | 12:54 PM
Planeswalker's Avatar
Depends on what year you have, 05' to like 07' is simple, after that you have to take everything apart. Well worth the effort if you get some good speakers. I got the Kicker KS68's, they are a direct replacement for the factory speakers and pretty much the best. You can find them online for around $65 shipped if you look.
EDIT: The Kickers come with all needed installation stuff. The harness from amazon was the wrong one.
Old Oct 1, 2011 | 02:31 PM
B1GP1MP1N's Avatar
Originally Posted by Planeswalker
Depends on what year you have, 05' to like 07' is simple, after that you have to take everything apart. Well worth the effort if you get some good speakers. I got the Kicker KS68's, they are a direct replacement for the factory speakers and pretty much the best. You can find them online for around $65 shipped if you look. Heres a link to the harness that makes then true plug n play.
http://www.amazon.com/gp/product/B0015G6JG2
Thanks for the info. Mine is an 07 so hopefully it wouldn't be too bad. I will check these out
Old Oct 3, 2011 | 01:46 PM
05PRMTX's Avatar
I dont know what your overall goals are, but in my opinion, if you get some good front speakers and amplify them correctly you dont really need to bother with the rear ones. They are more for sound fill than anything else. I guess it also depends on if you have the 500, 1000, ect.
Old Oct 3, 2011 | 01:52 PM
05PRMTX's Avatar
Yea I didnt know there was a difference between the years. I must have been looking at the how toos for an 08, I have an 05. Thanks for the info. Maybe ill do mine afterall lol
Old May 24, 2012 | 09:41 PM
mweeps's Avatar
From: Saint Albans, WV (Chesapeake, VA East Bank WV)
Crutchfield says they do not fit in the doors did you use them in that location?
Old May 25, 2012 | 01:13 AM
jaminlogic's Avatar
I replaced the rear speakers on my 05. The rear seat bottom, coat hooks, and side panels had to come out to lift the rear deck and access the rear speakers. Overall he process isn't bad.
Once all the panels are out, it wouldn't be a bad idea to put sound deadening material on the rear deck, and run cables (power, RCA cables, remote wire, etc) to the trunk for future stereo upgrades you might do later. I will post pics later on as well.
Old May 25, 2012 | 08:58 AM
Kevin509's Avatar
On an 05-06, it's real easy. I put Boston acoustics speakers in all the factory locations in my car. All I had to do was pop up the speaker grille, unscrew the old speaker and screw in the new one. I bought mine from crutchfield and they came with plugnplay wiring harnesses. On an 07+ though it's more difficult because you have to take apart a bunch of the trim apparently.
Old May 27, 2012 | 05:42 AM
jaminlogic's Avatar
My mistake...you do not need to remove anything except the grill to replace the rear speakers on an 05. I removed the panels to lay down sound deadener in the rear deck area.
Old May 30, 2012 | 11:21 AM
05PRMTX's Avatar
Did this a couple weeks ago. Looked like I had to pull everything from the rear seats to the side panles to get the rear ones out of my 05, so I did. Seems I put more effort in than I had to lol.
Old May 30, 2012 | 09:34 PM
jaminlogic's Avatar
I hear ya. I didn't even check to see if the grill came off until AFTER I took all the panels out. At that point I said to myself, might as well take advantage of the removed panels, and lay sound deadener and purchased an amp kit.
Old May 30, 2012 | 10:07 PM
Yes I used them in the doors, was a perfect fit, nothing else needed.
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
seaclam
Sep 25, 2015 01:29 PM
Evil_Capri
Sep 25, 2015 12:56 PM
