Pics of Dynamat install (door panels)
Old Oct 18, 2006 | 09:38 PM
VVVROOM's Avatar
Anybody have pictures of your dynamat (or other brand) installations in the door panels? I'm thinking about doing it soon, and I'm curious to see what I'm in for. If anyone has any tips, please send them my way.
Thanks!!!
Old Oct 19, 2006 | 11:03 AM
f1-cobra's Avatar
I have no pics, but I did do mine with SS Damplifier Pro.
I can tell you that there is more than enough room in there to cover the whole outer door skin (the one closest to the outside) in sound dampening material. The inner skin, however, will take a lot of small pieces to fill in the areas. Also, the vapor barrier will need to be removed and reinstalled with some new sealant.
Old Oct 20, 2006 | 06:59 PM
parrotheadGT's Avatar
Actually, you should be able to peel back the vapor barrier and simply press it back into place with the existing adhesive bead. That stuff is very sticky. I just pulled back one section at a time, installed the dynamat, stuck the vapor barrier back, and then moved on to the next section. I was afraid that if removed the whole thing, I wouldn't get it back in place correctly. there is plenty of room to work in the door panels, just keep using small pieces until you get it all in....
Old Oct 20, 2006 | 07:49 PM
Boltzman's Avatar
Watched mechanic take my door panel off today and vapor barrior seals back w/out extra goo. Make sure you have torx bits.I think there are two,could be more but can't remember
Ecostang
Nov 3, 2022 08:50 PM
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
roushcollection
Jul 28, 2015 02:08 PM
K.A.I.N
'10-14 Interior and Audio
Jul 20, 2015 06:42 AM
