Painting the XM Sat Antenna?
Old Dec 13, 2005 | 08:37 AM
2k5GTC's Avatar
Thumbs up
Ok you painters. Is it possible to paint my XM Satellite antenna body color, or will it destroy the reception? I hate seeing that black blob on the back of my vert. Thanks!
Old Dec 13, 2005 | 08:51 AM
thestoogeo's Avatar
I would say you can paint it with no loss of reception. I have mine sandwiched between the metal and carpet between the two back speakers and it works fine. Not to mention no one even knows it's there. I also have a GPS antenna hidden back there that works good. They both work in the garage as well.
Jon
Old Dec 13, 2005 | 06:32 PM
jvm051's Avatar
I have mine on the front dash. It is so small that I hardly even notice it there. I mounted it on the passangers side, next to the outer edge of the defroster vent. Signal is fine outside, in my garage it cuts out, but that is what the internet is for, and if you have Directv you can get it on there for free.
Old Dec 13, 2005 | 07:11 PM
Martimus's Avatar
Painting it body color should be no problem whatsoever. I put about 4 coats of mineral grey on mine and followed with some clear and now it looks awesome! I've seen no evidence to indicate that its degraded signal quality in the 6 months since I did it...
Old Dec 13, 2005 | 07:22 PM
KR3259's Avatar
should be fine, I have painted many aircraft antennas and radomes over the years, the new "mettalic" paints get their effects from mica and plastics so there is no metal to degrade the signal
I have my antenna in the left front corner of the dash, works just fine
Old Dec 14, 2005 | 06:45 AM
2k5GTC's Avatar
Thanks for the responses guys. I have an extra mini antenna I can use to test both putting it under the dash cover and painting it body color. I would rather not have it seen at all. Thanks for the ideas.
Old Dec 14, 2005 | 04:37 PM
SurfnSoCal's Avatar
get a black car?
Old Dec 15, 2005 | 07:44 PM
CANES fan's Avatar
double tap
Old Dec 15, 2005 | 07:45 PM
CANES fan's Avatar
Dumb question, but where do you get matching paint (Vista Blue) and about how much is it?
p.s check out O&A on xm 202. Funny stuff
Old Dec 16, 2005 | 05:44 AM
Martimus's Avatar
I used touch up paint to paint mine. You can either use the Ford touch up paint (available from the dealer) or the after-market stuff (I got a bottle of MG paint and a bottle of clear from Pep Boys).
Old Dec 16, 2005 | 06:50 AM
2k5GTC's Avatar
I have a spray can of Redfire and some clear coat I bought for the die cast model I have yet to tear apart and paint. Any auto paint supplier can mix you up some paint to match. I paid $12 or so plus $6 for the clear.
Old Dec 17, 2005 | 07:55 PM
alfman9's Avatar
What about putting the antenna underneath the front dash? Also, how will tinted windows affect my reception? And for anyone with gps & sat radio, did you run the two antennas to the same point? I was told that doing so would degrade the reception. Thanks.
Mar 30, 2021 09:29 AM
kponypower
Jun 17, 2020 07:17 AM
09-gt/cs
Oct 15, 2015 10:03 AM
PonyMuscletang13
Sep 29, 2015 09:40 AM
GLOCKer
Sep 28, 2015 05:20 PM
