Override dvd parking brake switch
Old Jan 20, 2007 | 02:41 PM
06TUNGVERTGT's Avatar
I just had my Pioneer AVH-P6800DVD installed and they insisted on doing the parking brake switch....how do I bypass it ?
Old Jan 20, 2007 | 07:07 PM
tom281's Avatar
I don't mean to come off as sounding short, but do a search- I've read it here somewhere but can't remember the setup exactly.
Old Jan 21, 2007 | 06:50 AM
mustang_lurkers's Avatar
Parking Brake Switch
I have the exact same DVD unit. It is easy to bypass the parking brake switch. You will have to pull up your center console and find the wire that goes the parking brake switch. Somewhere around there you will see where the installer spliced into it. You need to fix that splice and make your own using a small toggle switch. I mounted mine inside my center glove box where it would be hidden. I reused the parking brake circuit for my switch. Good luck and have fun with your DVD!
Old Jan 21, 2007 | 09:40 AM
Thanks for the info, I will give it a try...and I DID do a search...but could not find anything, maybe used the wrong terms....The IPOD control on this thing is the best $50 I have ever spent!!! Great Unit !!
Old Jan 22, 2007 | 01:45 PM
cruisin's Avatar
I would assume that you culd just ground the wire that they connected to your parking break. Find that wire shouldnt be hard to locate with the, they may have run it up the side
Old Jan 22, 2007 | 02:32 PM
1meanZ's Avatar
But will the toggle make the brake light come on in the dash?
Old Jan 22, 2007 | 04:15 PM
S197 GT's Avatar
3rd Times A Charm
This is the correct way to bypass this safety feature.
Don't be upset with the installer, they were following the law.
Old Jan 26, 2007 | 09:17 AM
My toggle switch doesn't affect the parking brake light on the dash. The circuit is not broken since you are just tapping into it. It is wired parellel wich makes it separate like the good christmas lights that won't kill all the lights when one burns out.
Old Jan 26, 2007 | 10:29 AM
hawgman's Avatar
I don't have the Pioneer, but do have the Kenwood and just grounded the park brake wire. Problem solved.
Old Jan 27, 2007 | 08:57 AM
YardSpecial's Avatar
But legal to talk on the phone.................
Old Jan 30, 2007 | 05:54 AM
Stig's Avatar
Just ground the wire to the e-brake to the chassis of the head-unit.
Job done
Old Jan 30, 2007 | 02:23 PM
Just Grounding The Wire Won't Work
Just grounding the wire won't work with the Pioneer DVD unit. I tried that and it still didn't work. You must use a toggle switch to simulate the movement of the parking brake switch. The Pioneer unit has a current sensor that picks up the current change when the switch actuates.
Old Jan 30, 2007 | 03:04 PM
This is true....I had the installer add a toggle switch for me. To be quite honest....I like the ability to be able to watch a dvd....but I am not going to drive around town all day and night watching one....but I did load in my aquarium dvd and play it while listening to my ipod.......the AVH-P6800 DVD is a kick a$$ unit, and I could not be more happy with it, plus I found it online for $800.00 half retail !!!!!
Old Jan 31, 2007 | 07:51 AM
Pictures
I would like to see your install jobs. Would you post pictures of it? Also do any of you plan to buy the performance diagnostics add on?
Old Jan 31, 2007 | 10:38 AM
ok here are some pics of the DVD, toggle switch and Sub
Attached Thumbnails Override dvd parking brake switch-dvd-1.jpg   Override dvd parking brake switch-dvd-2.jpg   Override dvd parking brake switch-dvd-3.jpg   Override dvd parking brake switch-sub-1.jpg   Override dvd parking brake switch-toggle-1.jpg
Old Feb 5, 2007 | 10:56 AM
Stig's Avatar
Really? My mistake then.
It certainly worked with my AVIC-X1R?
NC14GT
Sep 10, 2017 04:47 PM
ricky1728
Feb 11, 2016 07:25 PM
NC14GT
Sep 27, 2015 05:35 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
