Need Help w/Punch S2 Door Sub
I am trying to replace my factory door subs with some Rock Fosgate Punch Stage 2s and need some help. The factory sub has 4 wires going to it (2+ and 2-). My S2s only have two connections (1+ and 1-). Should I connect both factory +/-s together to their respective S2 single terminal or should I bridge somewhere?
Help Please
Help Please
You have a problem. The factory speaker is a dual voice coil sub driven by two (each) amps. While it is pretty easy to drive multiple speakers with a single amp channel, it is a lot trickier to drive a single voice coil with muiltiple amp channels. Magic smoke tends to be released, either very quickly or eventually if everything isn't perfect.
That leaves you with two choices: Only use one of the amp channels to drive the sub or get a speaker that has dual voice coils.
Also, be aware that the factory sub is rated at 1.2 Ohms per voice coil. Most aftermarket speakers come in 2, 4, or 8 ohms per coil (assuming multiple voice coils) configurations.
It's not quite as bad as it seems. When I replaced the factory subs in my car with JL Audio 8W3V2s, I measured the resistance of the factory coils (not the impedence, but the actual resistance) and it came in at a measured 1.6 ohms. That is a LOT higher than I would expect for a voice coil rated at 1.2 ohms. Basically, the impedence should be the resistance plus what ever additional impedence is added by the capacitance (low) and inductance (VERY HIGH) of the voice coil. So if I am measuring 1.6 ohms resistance, then the actual impedence MUST be greater than 1.6 ohms.
The voice coils on my 8W3V2s measured out at 1.8 ohms resistance (in the ball park of what i would expect for a 2 ohm speaker), so the actual difference is pretty small.
![Nono](https://themustangsource.com/forums/images/smilies/nono.gif)
RRRoamer, thanks for clarifying that. Can we call those factory jobs "2 ohm subs" since that designation is only nominal for any driver anyway?
I tried bridging one channel to no adverse (or positive) effect. The way I understand it, if an amp is not bridgeable, both negative channels are in phase w/ each other, so there would be no difference whatsoever. I'm sure there is some potential for harm, I just can't think of why
Originally Posted by #6Fan
Does anyone know what kind of watts the factory amps for the door subs are pushing out?
That part I didn't check, I knew I was only half-doing it. I got so caught up in listening that I didn't look. I wonder if the amps are well-made to the point where their outputs are fairly equal?
