MP3 Player
Old Nov 9, 2004 | 08:06 AM
JustAnotherDude's Avatar
Originally posted by ace0215+November 9, 2004, 8:32 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (ace0215 @ November 9, 2004, 8:32 AM)</td></tr><tr><td id='QUOTE'>
Originally posted by JustAnotherDude@November 8, 2004, 4:32 PM
Originally posted by Stadifer@November 8, 2004, 3:53 PM
<!--QuoteBegin-I8URVTEC
@November 8, 2004, 3:46 PM
To "burn" an MP3 cd all you need to do is create a "data" not a "music" CD using whatever program you use to create CDs on your computer. You then write the MP3s directly onto the CD in their MP3 format. You should be able to fit between 100 and 150 songs on each CD. If you are only able to fit about 20 songs you are making a music CD and not a data CD.
What bit rate are you running on those MP3 files? Even compressed you probably won't fit 100 songs onto a 700mb CD with a high bit rate. I'm not an audiophile so maybe I'm wrong but 100 to 150 with decent sound seems a bit high for a single CD.
As far as ease of use with a 6-Disc in dash unit they are easy to use. When you insert a CD you simple select the position you want to insert it to from the face (using the pre-set buttons while on CD mode). To eject you press the eject button and select the CD position you want to eject with the station pre-set buttons again.
I don't know if the deck displays song title and info from MP3's though?
There's no use in more than 192 kbit... a CD doesn't have higher quality, so ripping/burning at, say, 256 kbit is just wasting a lot of space for...static. It won't improve quality since the CD is a pretty sh*tty medium for sound storage to begin with.
umm...maybe you'd prefer 8 track? [/b][/quote]
Hahah, well if we're speaking amount of sound data that can be transferred, yes, 8 track is not that bad... My point was that since the CD bit rate is limited to begin with, there's no use in inflating file sizes by applying a higher bit rate to the mp3 rip. That's only useful if you rip off a vinyl record or directly from a digital recording source.
Old Nov 9, 2004 | 08:12 AM
holderca1's Avatar
Originally posted by ace0215+November 8, 2004, 2:26 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (ace0215 @ November 8, 2004, 2:26 PM)</td></tr><tr><td id='QUOTE'>
Originally posted by RaGsHoCkEy88@November 8, 2004, 2:23 PM
<!--QuoteBegin-holderca1
@November 8, 2004, 12:37 PM
It's a 6 disc MP3 player, why would anyone ever need to upload songs to it.
i second that
there are benefits to a hard disk based mp3 player. and even with 6 cd changer you are still limited to 4.2 GB. Probably only 60 - 70 albums [/b][/quote]
Actually it's not quite 4.2 GB, 1000 MB does not equal 1 GB.
Old Nov 9, 2004 | 08:19 AM
Falchion's Avatar
I've heard that the Shaker systems will alos play WMA files? Is that true? Don't those give better quality and smaller file size?
Old Nov 9, 2004 | 08:42 AM
I've seen statements supporting both ends, but technically yes - wma is better than mp3 when it comes to compression and quality. I'm on the fence though.
Old Nov 9, 2004 | 09:43 AM
BillP's Avatar
192kbit is a bit low, even for a car.
The Shaker500 has enough treble detail to show the poor quality of 192Kbit recordings (and 160kibt sounds horrible). I am sticking with 220 VBR and better.
And the 330VBR recordings I have of Led Zeppelin sound fantastic in my new Stang...
Old Nov 9, 2004 | 10:17 AM
Stadifer's Avatar
Originally posted by I8URVTEC@November 9, 2004, 9:08 AM
This is why they say with the 6 CD changer you can have like 48 hours of music loaded up.
Push shuffle and you have your own radio station.
Old Nov 9, 2004 | 10:49 AM
ace0215's Avatar
I thought that might be funny! i think you might be a little confused. A music CD only has room for 74 minutes worth of music (Uncompressed WAV format). MP3 Compresses the music. The amount of compression is determined by the bit rate. The higher the bit rate the less compression, thus the closer to the original source, but the bigger the file size will be. On the other hand the lower the bit rate the smaller the file size will be but the more compression and less quality you will have.
you are not "inflating" the file sizes as MP3 is compressing the WAV format from the cd.
Old Nov 9, 2004 | 10:50 AM
ace0215's Avatar
Originally posted by holderca1+November 9, 2004, 9:15 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (holderca1 @ November 9, 2004, 9:15 AM)</td></tr><tr><td id='QUOTE'>
i second that
Actually it's not quite 4.2 GB, 1000 MB does not equal 1 GB. [/b][/quote]
I know that, but it's just an approximation just like hard disk manufacturers do. No need to confuse people if you know what i mean
Old Nov 9, 2004 | 10:51 AM
ace0215's Avatar
i don't believe the shaker supports WMA
Old Nov 9, 2004 | 12:06 PM
Eric B's Avatar
I can't believe people still use fixed bitrates :scratch:
Old Nov 9, 2004 | 12:28 PM
ace0215's Avatar
people "use" whatever the bit rate was when they downloaded the song
In all honesty that's probably how most people get their MP3s. Legally or not. I would say the minority comes from people ripping their own cds.
Old Dec 31, 2004 | 12:03 PM
davids2toys's Avatar
How can I turn WMA files into MP3 files so it will read them?
Old Dec 31, 2004 | 12:53 PM
Jeffs05GT's Avatar
Ive been looking for a good program to do this also, as I don't want to go back and rerip 100+ cd's, ugh!
07 Boss
Aug 8, 2015 11:04 AM
Mellow Yellow
Off-Topic Chatter
Jan 20, 2005 02:51 PM
BillP
Nov 4, 2004 04:20 PM
2001GTMILT
Oct 22, 2004 11:00 AM
