Lighted Sill Plate problem
I am trying to install the mustang lighted sill plates and have run into a problem. I carefully
followed the instructions but when I hooked the battery back up there was no pretty lights.
I went back and put a V meter between the light green/yellow stripe wire and the black/light blue
stripe that I hooked into and got no voltage. I must have blown a fuse but I can't locate it. Does
anyone know which fuse is connected to that circuit?
Thanks,
Wayne
Thanks,
Wayne
Solved
It turns out that the fuse for that was for the lighted sill plate circuit was the same one that
I had used for my remote amp turn on using one of these
![](http://ep.yimg.com/ca/I/sports-imports_2073_59453756)
and while the remote amp turn on functioned and both fuses were good, the original circuit
was not working. I pulled out the add-a-circuit and put in a fuse and that and the sills worked.
I plugged the add-a-circuit into an empty spot and the remote amp turn on functioned.
-Wayne
-Wayne
mustanglindsey
8/3/15 09:07 AM
