Lighted Sill Plate problem
Old Sep 26, 2009 | 03:15 PM
wht67's Avatar
I am trying to install the mustang lighted sill plates and have run into a problem. I carefully
followed the instructions but when I hooked the battery back up there was no pretty lights.
I went back and put a V meter between the light green/yellow stripe wire and the black/light blue
stripe that I hooked into and got no voltage. I must have blown a fuse but I can't locate it. Does
anyone know which fuse is connected to that circuit?
Thanks,
Wayne
Old Sep 27, 2009 | 04:33 PM
wht67's Avatar
Solved
It turns out that the fuse for that was for the lighted sill plate circuit was the same one that
I had used for my remote amp turn on using one of these
and while the remote amp turn on functioned and both fuses were good, the original circuit
was not working. I pulled out the add-a-circuit and put in a fuse and that and the sills worked.
I plugged the add-a-circuit into an empty spot and the remote amp turn on functioned.
-Wayne
Old Oct 10, 2009 | 07:30 PM
roush235's Avatar
Always nice to have solved your own problem. I have a set ordered, any other words of advice for the installation?
Old Oct 15, 2009 | 06:30 PM
partsbill's Avatar
I just installed my lighted sills also.
Old Oct 15, 2009 | 06:45 PM
David Young's Avatar
Those look great!!!
mustanglindsey
Feb 15, 2026 04:48 AM
Good Times
Aug 29, 2015 10:18 AM
rickey7575
Aug 21, 2015 11:40 PM
Will3212
Jul 16, 2015 10:30 AM
