Leather Shift Knob
Old Jul 31, 2008 | 10:04 PM
iceking32's Avatar
Leather Shift ****
I've got the IUP Metallic Shift **** right now. But this summer, I've nearly burned my hand a couple of times after the thing got hot in the sun or even from just the heat inside the car. I want to switch it to something that has a clean look but is not going to absorb heat so easily.
Has any found a leather shift **** or other material to go with an Satin IUP interior with black leather?
Old Aug 1, 2008 | 06:23 AM
ronslakie's Avatar
If you go to the MGW site at www.mgwltd.com they have ***** made of composite material that are not affected by heat or cold in both a 5 speed format or a GT format that will work . I have had mine for over a year.
Old Aug 1, 2008 | 06:31 AM
05GT-O.C.D.'s Avatar
I lust for a M24
Grabberpony.com can make you a shift-**** in whatever color and design you'd like, but it'll be a 'pool ball' style **** (so I don't think they can do leather). Great price and service at grabberpony.com
Old Aug 3, 2008 | 07:28 AM
2k5GTC's Avatar
When I owned my '87 GT I had the hard plastic shift **** covered in leather by an upholstery shop.
Old Aug 3, 2008 | 08:15 AM
dmhines's Avatar
The IUP interior comes with a Leather **** ... you must be talking about the Premier Trim package with the Billitt Aluminum ****. Here's the standard IUP shift **** ..
I did put on the Billitt one recently and it does get VERY hot ...
Old Aug 3, 2008 | 09:06 AM
Cavero's Avatar
UPR makes a composite shift **** too. Goes great with the IUP and I've never burned my hand on it.
http://www.uprproducts.com/shopping/shopexd.asp?id=1054
Old Aug 3, 2008 | 10:23 AM
titanjc's Avatar
It definitely doesn't match the satin IUP color, but I really like my white Roush cue-ball style shift ****. It's always cool to the touch, and has a great look to it. The aforementioned Grabberpony.com ***** would the be pretty much the same I would assume. Can't go wrong with either.
Old Aug 3, 2008 | 10:42 AM
NJ3's Avatar
NJ3
The leather Saleen Extreme **** matches the interior. But the top of the **** gets hot because it's exposed billet. I have one that I use but I also use a MGW gripper and a Grabberpony ****. http://cgi.ebay.com/ebaymotors/ws/eB...ksid=p3907.m32
Old Aug 3, 2008 | 10:45 AM
watchdevil's Avatar
Put a sock on it when you park it!
Old Aug 5, 2008 | 07:54 AM
metroplex's Avatar
The Premiere trim billet shifter looks like a phallus. Putting a sock on it just sends out more innuendo!
FWIW, I have the cheap non-IUP base shift ****. It is wrapped in black rubber, the shift pattern is black with silver text overlay and a clear plastic cover. It looks exactly like the IUP shifter, but does not have any silver coloring other than the text for the pattern. The silver-painted "ring" on the IUP shifter is black on the base shifter.
I park it frequently in the sun and it does not get hot enough to burn my hand, but everything does get quite hot in the summer. I often wondered about having so much alloy in the interior. I remember my 81 T-bird with its OEM alloy everything and how I would get 3rd degree blisters on my hands, legs, and arms during the summer. Thank the Ford engineers that chose to "cheap out" the car with black plastic/rubber/polymer.
Old Aug 5, 2008 | 02:57 PM
Cavero's Avatar
The one on the 911 GT3 is even worse
Old Aug 6, 2008 | 02:15 PM
metroplex's Avatar
Here's the stock non-IUP base shifter.
Old Aug 7, 2008 | 08:48 AM
frdtch05gt's Avatar
I have a grabberpony **** as well, it's fun to shift gears with and doesn't get extremely hot, very pleased with it.
Old Aug 7, 2008 | 04:45 PM
houtex's Avatar
wow... if it weren't for the rest of the IUP stuff I gots, i'd figure out a way to put that black top on the IUP shifter. I like it awesome.
/now thinkin'...: What else'd be good in black instead of silver inside...?
//Door handles... Yeah, I think they need to be black now. Yep, that's the ticket.
Old Aug 7, 2008 | 05:29 PM
metroplex's Avatar
My non-IUP door handles are black.
Old Aug 25, 2008 | 03:39 PM
Phorty's Avatar
I'm also looking for other **** options. I just bought a MGW Gripper and I'm not digging it so far. Very nice quality but too big and it raises the height of the **** when installed.
Gigantor
May 11, 2023 07:31 PM
kponypower
Jun 17, 2020 07:17 AM
K.A.I.N
Sep 25, 2015 03:27 PM
SterlingStunner
Sep 16, 2015 12:30 PM
earl610
Sep 6, 2015 05:48 PM
