Installing Raptor, need 12v switched source.
Old Jan 21, 2008 | 06:43 PM
bentpushrod's Avatar
I'm in the process of installing a Raptor shift light. I have my Shaker 500 head unit pulled. Hoping someone can tell me the color of wire that is switched 12v. I need to get this buttoned up in the next hour or two.
THanks.
Old Jan 21, 2008 | 09:00 PM
Found a power source. Light works great.
Old Jan 22, 2008 | 08:38 AM
krnpimpsta's Avatar
What did you use?
Old Jan 22, 2008 | 04:52 PM
I spliced into my Shaker 500 harness. White wire going into pin # 2 on the big plug.
Old Jan 22, 2008 | 06:52 PM
krnpimpsta's Avatar
Is that the switched 12v that stays on for a few minutes after the engine is off, or until the door opens? Or does it go off instantly with the engine?
I just completely uninstalled all of my audio/etc so the dealer could fix an electrical problem (that I probably caused). Previously I was tapping into the clutch sensor, but I that's not really a great solution.. I'd like a better switched 12v that doesn't come from anything important. So when I put everything back in this weekend, I want to do it right.
Old Jan 23, 2008 | 07:12 PM
traffic142's Avatar
photos please
Old Jan 25, 2008 | 08:35 PM
07Foose's Avatar
I'll take some pic's of my install in morning. I used the "Add a circuit" from Advance Auto plugged in to the passanger kick panel...
Old Jan 26, 2008 | 09:44 AM
flamin ponyexpress's Avatar
There is a swith under the drivers side around the brake clutch assembly, it is Blue, this is a switch power source.
use the wire with the tracer on it. ( one with the stripe )
FromZto5
Sep 30, 2015 05:28 AM
Evil_Capri
Sep 11, 2015 08:39 AM
Sep 10, 2015 12:44 PM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
