Installed XM Radio
Old May 22, 2005 | 12:15 PM
05redfiregt's Avatar
[attachmentid=21882][attachmentid=21883][attachmentid=21884]Installed my XM radio between the two dash vents. It fits perfect and the extra wire tucks right behind the unit. Mounted the antenna on the trunk lid.
Old May 22, 2005 | 12:19 PM
Pretty Blue Stang's Avatar
Is it wired into the amp? Describe a little more, cause I've thought about one of those.
Old May 22, 2005 | 12:24 PM
No I used the power cord FM modulator, you set the car stereo to a channel and it picks the Xm broadcast it works great.Thats actually the modulator plugged in the power outlet right below the radio.
Old May 22, 2005 | 11:51 PM
Snets's Avatar
05RedfireGT, can you also post some pics, or send a link if already posted, of your CDC dash kit?
BTW, nice camera (Canon 10D) my dad just got a 20D and I have a Nikon D70, nothing like a DSLR for photos of our 05's....
Old May 23, 2005 | 06:49 AM
[attachmentid=21966]This is all I have here can take more if you need them. Ya the camera is awesome.
Old May 23, 2005 | 07:07 AM
Martimus's Avatar
When I installed mine I got a bit more creative with the location. I really didn't want it sitting on the dash where someone could more easily see it. As such I mounted it on front of the accessory light console. Both cables (power and antenna) got ran under the headliner, down the A pillar, the power split off to the fuse box while the antenna ran back to the trunk compartment.
I painted the antenna cover Mineral Grey using touch up paint I received. Now the antenna blends into the trunk lid a bit better. And reception remains good!!
Old May 23, 2005 | 08:15 AM
gmichael's Avatar
Martimus
Can you give us a picture of the interior mount from a little further away (for perspective)? Thanks
Old May 23, 2005 | 08:21 AM
Axslynger's Avatar
You guys notice any scratches yet from underneath the antenna??? I'm looking for a different place for mine because of just that. Anyone have any better antenna locations??? Mine won't work inside the car, so thats out. Already tried.
Old May 23, 2005 | 08:30 AM
subzero05's Avatar
I put my kenwood krc-70 display unit in the same location as you and it looks very nice.My display is a slim line design that fits perfectly between the two sensors for the alarm and is integrated perfectly because it is only about 1.5in wide and 6-7 in long
Old May 23, 2005 | 08:35 AM
hawgman's Avatar
That sux. Sirius or XM? I installed Sirius on mine and put the antenna in the rear deck and reception is fine. Even works with the car in the garage.
Old May 23, 2005 | 08:53 AM
Axslynger's Avatar
It's XM which I'm lovin' BTW. Can't get reception unless it's outside the car.
Old May 23, 2005 | 09:41 AM
Mines Xm, no scratches anywhere...
Old May 23, 2005 | 02:33 PM
subzero05's Avatar
sirius here.
Old May 24, 2005 | 01:16 PM
robynspony's Avatar
I have the Sirius Sportster in my Ranger which is FM modulated. I'm waiting to put a nice system in the Mustang. I wouldn't go with the FM Modulated type for the Mustang though. The quality is not nearly as good as having it's own tunner. If you have a signal on the station you are using the modulator on it will come through. I drove to FL and had to change stations several times. Its a pain in the butt. You can't beat the programing of Sattelite radio though, it's awesome
Old May 24, 2005 | 07:43 PM
05windveilbluegt's Avatar
i saw a thread some time ago where a guy mounted the antenna inside his car under the rear window with perfect reception.
Old Jun 22, 2005 | 08:16 PM
RARE 5.0 NOTCH's Avatar
I have my antenna mounted inside my gto and get perfect reception.And will be doing it on my 06gt when i get it. cant wait for that.
Old Jun 26, 2005 | 10:06 AM
teddybear1255's Avatar
Hubby just installed XM Commander in my Stang........
Old Jun 30, 2005 | 11:16 AM
azlitigator's Avatar
I have a MyFi XM unit. It's portable so you can use it like a Walkman and we switch it between cars. I put the antenna on the trunk lid on the black vinyl stripes, and ran the wire under the seats, then under the console and Dremeled a small gap in the bottom of the snap little door thing. The wires are long enough so I can pull it out to change stations, but for the most part I leave it alone unless I'm at a stoplight or something. I like the fact that it is out of sight and is movable from car to car.
[attachmentid=26144]
Old Jun 30, 2005 | 10:31 PM
CelticNut's Avatar
It might have been me...
http://forums.bradbarnett.net/index.php?showtopic=25443
Old Jul 1, 2005 | 04:09 AM
Clem's Avatar
In my '05, the antenna for my XM Commander is in the center of my dash, all the way up near the base of the windshield. I guess I was too lazy to run it to the back like most have done. On my first test drive, I dropped the signal before getting out of my neighborhood! :shock: But since then, it seems to work pretty well. In fact, about as well as the one on the roof of my 2004 F-150 in the recommended location. However, both are pretty much blocked out by any decent size patch of overhanging trees. With all the repeaters here in the DC area, you would think I wouldn't be having as many drop-outs. Is anyone else having trouble with their signal?
PonyMuscletang13
Sep 26, 2015 02:33 PM
MustangGTCS13
Sep 17, 2015 07:38 AM
Sep 10, 2015 12:44 PM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
