How hard is it to install gauges?
Old Jul 31, 2012 | 09:09 PM
Corstang427's Avatar
I have just purchased the Auto meter tri pod for my mustang. I was curious about two things, one what gauges should I get for my supercharged stang ( boost is obvious), and two how hard is it to DIY? Any tips and suggestions would be helpful.
Old Aug 1, 2012 | 07:30 AM
05YellowGT's Avatar
You'll also want a wide-band A/F gauge and I like having fuel pressure too. As far as installing it I had the CDC dash pod which is similar to yours and the wires ran down the defrost vents at the windshield. Take out the instrument cluster and you can get access to the bottom of the vents to pull the wires through ...
Old Aug 1, 2012 | 07:57 AM
Doogie's Avatar
Check out scan gauges like Aeroforce as they have a ton of flexibility and can monitor a wide range of OBD functions as well as several analog inputs. I have a dual set of these in my car and added the seperate MAP for monitoring boost. They also have a nice A/F add-on as well.
Old Aug 1, 2012 | 11:17 AM
05YellowGT's Avatar
+1 on the aeroforce gauges I have a set too and get my boost and fuel pressure from them , but I have an innovate gauge for the A/F ratio which works out nicely with a 3 gauge pod ...
Old Aug 1, 2012 | 09:03 PM
I only have a budget of $350 left to spend. How much are the aeroforce gauges? Also what color do regular auto meter ultra lite gauges light up too?
Old Aug 2, 2012 | 05:14 AM
05YellowGT's Avatar
Here's a link to the scan gauges , you find them other places too
http://www.lethalperformance.com/mus...-gauges-1.html
Old Aug 2, 2012 | 06:55 PM
I like the scan gauges but just too expensive.:/ I think I'm going with auto meter cobalt mechanical gauges.
Jim74656
May 1, 2023 02:15 AM
Jul 8, 2016 08:53 AM
Good Times
Aug 29, 2015 10:18 AM
DarrenGT
Aug 21, 2015 07:07 PM
