ground
ground
where have you guys ground out your amps when placing them in the trunk. i don't think my amp is grounded sufficiently, and thought someone might have a better suggestion.
thanks
thanks
I haven't messed with the mustang radio at all but where do they ground the factory amps and how are they terminated? Maybe you could ground i the same general location. Regardless make sure you get ride of the paint between the lug and whatever your grounding to for a better connection as mentioned.
Bolted mine under the "Latch" bar, underneath the back seats. Uses a T60 like a seat belt does. Just bolt it under there "after sanding the metal for a good contact". I've done three 'Stang sound systems with various amps and all are nice and clean sounding.
Tim
Tim
